the problems continue
Old Mar 15, 2003 | 02:50 PM
Broken09's Avatar
I am becoming...
Ok so I finished the Vac hose job. Got everything back together. Checked all my connections. Car turns over but wont start, so I figured ok it's flooded. Pulled the plugs and turned it over got some gas out and then replaced em and tried it again. No luck seems like I'm not getting a spark from the plugs, so I checked the fuses on the positive battery lead. I'm going to replace them and put them in tonight and check for codes.... anything you guys can think of I'm overlooking? Thanks and thanks again for all the help in the past.
-Nic
Old Mar 16, 2003 | 08:59 PM
Broken09's Avatar
I am becoming...
ok so I replaced the four smaller fuses on the battery lead the three 30A and the one 40A the 120 looks fine. I checked for error codes and no luck... I really need some input guys!! Thanks
-Nic
Old Mar 16, 2003 | 10:05 PM
apeiron
did you do the non-seq conversion??
Old Mar 17, 2003 | 07:23 AM
Broken09's Avatar
I am becoming...
No i didn't I just went back to Sequential... I'm planning on going single when I do the engine rebuild since my engine will need it soon. I just don't know why it's not starting now.... I changed the hoses on the map sensor and that's when all of this started. Didn't really understand why. My battery died and I recharged it and then the car wouldn't start, so I went ahead and did the vac job and double checked all my connections and still won't start. So i'm really at a loss.
-Nic
Old Mar 17, 2003 | 07:38 AM
paw140's Avatar
Have you actually checked for spark? Your engine may just be flooded. Change your sparkplugs and try again.
Old Mar 17, 2003 | 08:11 AM
Broken09's Avatar
I am becoming...
I'll give that a try I was planning on doing that tonight.... if I'm not getting spark what could my cause be?
ZacMan
Sep 19, 2015 09:20 PM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
sinistersam
Sep 13, 2015 07:17 PM
