* 3rd Gen Junkyard Parts Source *
Old Mar 15, 2003 | 10:09 AM
Resource's Avatar
While redoing my fuel system I had to move around my brittle wiring harness quite a bit. As you know this always leads to wires breaking off right at the tip of the connectors. Althought one might think that the only thing to do is buy a brand new wiring harness from MAZDA, this isn't the only resort.
I broke off the coolant sensor, 2 injector connectors and a crank angle sensor connector.
I started to think that these dang connectors should not be RX7 specific so I took a ride down to the local junkyard and started looking. I brought my old connectors down to match them up. There were no 3RD GEN RX7's there of course so I went to the next best thing. I went searching on 2 different cars and found all the connectors I needed in perfect condition. I found it all on a 93 protege and a 94 626. These connectors are on other year cars but I found the best condition ones on these particular ones.
Anyways I ended up with practically new 13 connectors and re did my wiring harness.
I also found that you can find all the solenoids and check valves on these cars too.
Oh yeah, I paid 1 dollar for each of them. Not too bad.
Old Mar 15, 2003 | 11:10 AM
FormerPorscheGuy's Avatar
Yes it is for sale.
Thinking out of the box is always a plus and usually saves a lot of money. Good job.
patriick's Avatar
FD enthusiast
good post, thanks
Old Mar 15, 2003 | 11:26 AM
Ward's Avatar
Unconfirmed
i got my connector for my Miata thermo-switch off of a mid-90's 626
Old Mar 15, 2003 | 12:04 PM
Goober's Avatar
de doober
I just got mine yesterday at the local import yunk yard off a mid 90's 626 too. It is a great alternative to going to the dealer and buying a whole new harness though.
Old Mar 15, 2003 | 07:45 PM
Resource's Avatar
Make sure you cut yourself plenty of extra wire from the junkyard connectors so you have plenty to work with.
Old Mar 17, 2003 | 09:04 PM
Resource's Avatar
Just making sure everyone has seen this.
Old Mar 18, 2003 | 03:20 AM
BoostedRex's Avatar
NorCal 7's Co-founder
Great post!! Thanx bro.
Old Mar 18, 2003 | 12:58 PM
Resource's Avatar
No problem, just trying to save everyone some money and headaches.
Old Mar 18, 2003 | 01:20 PM
jdhuegel1's Avatar
Glug Glug Glug Burp
Good info man!
You still need to get me directions to the new place of employment! I wanna check out the progress!!
Old Mar 19, 2003 | 02:01 AM
lane_change's Avatar
It has begun
Hey Eric....what if I brought you my wiring harness...do you think you could open it and remove all the **** I don't need and reaplace my broken clips? I will be in STL on Friday the 21st, if I could meet up with you to see your fuel setup and see how you did your wiring harness. I already have my harness removed and I was about to cut it open and remove all the **** I don't need anymore, I would love to see your wiring harness and if you could show me what junkyard you went to, that would be awesome. PM me about this.
Scott
Old Mar 19, 2003 | 08:22 AM
Poppinrex7's Avatar
damn...thats a pretty good tip...new harness is probably around $2k...or something disgusting like that....
Old Mar 19, 2003 | 01:29 PM
Resource's Avatar
Scott
PM'd you.
