who makes custom ic piping?
Old Mar 14, 2003 | 12:15 AM
2manytickets's Avatar
who can make custom ic piping? anyone have a good idea? I know exactly what I need and the angle of the bends already as well as lenths
Old Mar 14, 2003 | 01:22 AM
Dougie_fresh_007's Avatar
your local muffler/exhaust shop should be able to do it
Old Mar 14, 2003 | 11:26 AM
Trout2's Avatar
I made my own, its not that hard if u already know lengths and angles. Its not cheap even if you do it yourself.
Go to BurnsStainless.com, order the bends and straight lengths u need (use aluminum 6061 for intake piping). Hint: if u need two 90 degreee bends, get a 180 and cut it in half to save some dough. Once u get the material, cut it using a band saw (easiest), hack saw works too. When close to cut dimensions, use an electric sander to take off small amounts. Another good reason to DIY is so that u can test fit it. Once its fitted, mark the pieces and take them to a local person who can weld aluminum and put a bead on each end of the pipe.
Old Mar 14, 2003 | 11:32 AM
neoamd's Avatar
LS Powered
What IC do you have Trout2 and what bends did you get
Josh
Old Mar 14, 2003 | 12:42 PM
neoamd's Avatar
LS Powered
Chil;d performance Exaqust here can do it. Buy the pipe then they weld them.. good stuff.. i found i can make a complete IC kit for myself for like 400$.. NPR baby w00t!
Old Mar 14, 2003 | 02:59 PM
Trout2's Avatar
I made an s-pipe to use the Crooked Willow IC with Efini y-pipe. Used a 180 bend from Burns.
See this link for pictures of the pipe - http://ourworld.cs.com/_ht_a/talvendi/id19.htm
Other tips: Be careful when working with the Aluminum piping because it is soft and will dent easily. To help cut straight lines when using a hack saw (band saw works best), use an old coupler as a straight edge. Be careful with the sander becasue the soft metal gets eaten away fast if you don't pay attention.
Old Mar 14, 2003 | 04:23 PM
yeah
they muffler shops in a town near u lol polishing u might have to do urself, but its no diff than exhaust piping, i have had a couple of buds get it done at a muffler shop... it shouldnt be a problem,
jza80
Dec 6, 2015 05:53 PM
