Sponsored by: CARiD
Oil Leak
Old Mar 13, 2003 | 06:52 AM
DrunkenBowler's Avatar
Oil Leak
If you blow an oil ring or an oil seal, will you drop oil onto the floor?
My rx-7 is dropping oil right now and I need help.
Old Mar 14, 2003 | 02:47 AM
duboisr's Avatar
If the front or rear main seals go bad the oil will hit the floor, Get under the car and clean the motor with carb cleaner then run it and look for leaks. The oil pans will leak as well as the seals , check the front cover too . Third gen turbo oil lines will leak . Check the lines to the oil cooler ,the coolers crack where the fittings screw in .
rotor_veux
Sep 3, 2015 07:10 PM
sypath
Aug 16, 2015 12:06 AM
