Microtech Microtech installed-need help
Old Mar 12, 2003 | 08:46 PM
Turbo Timmy's Avatar
Professional Lurker
Ok so I got the car today and Rolo is out of town so I tried to get it running. It seems to be running ok but is real rich and breaking up bad.
Is there a map I can just download to get the car running ok? I've tried messing with eveything and nothing seems to change.
Also the map sensor only is showing boost not vacuum and I think that's part of the problem any reasons why this would happen?
Old Mar 12, 2003 | 09:00 PM
10sec rx7's Avatar
If the map sensor is only showing boost you have it hooked into the worng side of the throttle body, it needs to go between the rotors and the throttle body, i find a good place is where the top if the manafold join the bottom of the manafold, there is a vacumme point there,
it will be rich because it is using the 0inhg map not the 15 or 20 map it should be using at idle.
When you say breaking up, is it in the top end??
Dale
Old Mar 12, 2003 | 09:41 PM
Professional Lurker
It's hooked up to the back of the TB right where the three vacuum lines hook in. Right by the throttle cable. Could it be a bad map sensor?
yes it starts breaking up at high revs (over 4k). It starts out low like a blown motor then clears out a little then breaks up and flames shoot out the back.
The main problem is timing it seems. If I got that right taking out fuel is easy.
Old Mar 12, 2003 | 10:16 PM
10sec rx7's Avatar
if i remember correctly one of them is not a good source,
try hooking it into the one at the back of the manafold just to see what it does,
do you have a boost guage?? does it read vacumme?? you could T off that line and compare the readings.
i would say that the map sensor is not hooked up right at all, if it starts off bad then comes good then goes bad as the boost comes up id say the map sensor is not reading anything at all,
Old Mar 12, 2003 | 10:19 PM
10sec rx7's Avatar
the middle port on the 3 ports only has vacumme/boost when the throttle is opened, if you have it hooked to the middle one hook it to the bottom one.
if you have it in the middle one that will be your problem
http://www.hitman.hm/S4-manifold-s.jpg
dale
Old Mar 13, 2003 | 05:46 PM
kabooski's Avatar
Laying Down Rotary Law
Did you zero the timming?
Old Mar 14, 2003 | 04:29 AM
rxeng's Avatar
Tim.
Give me a call at the workshop on 61 2 49661235.
I'll talk you through it all.
Don't go fiddling with the base map.It will be pretty close as it is.
Sounds like the wrong map line connection but give me a call anyway & we'll get it sorted.
Jon
Old Mar 14, 2003 | 11:08 PM
Professional Lurker
Thanks Jon!!!! Got the car running (and boosting a little hehe) but it's still really rich. The map sensor was the problem. Hopefully will get it fully tuned this week when Rolo gets back.
eddierotary
Engine Management Forum
16
Oct 4, 2016 08:22 PM
frijol
Microtech
Sep 23, 2015 12:51 PM
freq
Haltech Forum
Sep 13, 2015 07:45 AM
