Got Mallory Comp 70, need advice
Old Mar 12, 2003 | 01:16 PM
inittab's Avatar
I read your email
I just picked up a brand spank'n new Mallory Comp 70 and I'm planning out my installation now. I'll be installing a Holley regulator but I'm wonder where I should install a second fuel filter. Should it be before the regulator or after and what fuel filters do you recommend? TIA
Old Mar 16, 2003 | 01:35 PM
inittab's Avatar
I read your email
Out with the old and in with the new.
Old Mar 16, 2003 | 01:40 PM
inittab's Avatar
I read your email
Installed
Old Mar 18, 2003 | 09:26 PM
82transam's Avatar
Never Follow
pfft, bah, mines bigger
Old Mar 19, 2003 | 12:20 AM
SoRRoW's Avatar
MY NEW NAME IS ROTARY 7S
I got 2 fuel filters on my car
1-between the tank and my Holley pump
2 inline clear one-on the firewall before the regulator/before the carb.
Old Mar 19, 2003 | 06:37 AM
Maguire's Avatar
Born 2 Brap
Nice job, where did you mount it? All i can see in the pic is that theres a brake line next to it.
Old Mar 19, 2003 | 06:58 AM
85RX7GS's Avatar
Looks like it's mounted in front of the fuel filter (back of car in front of gas tank).
Put your filter before the regulator, otherwise you'll be regulating fuel into a restrictive filter and catching crud after it goes through your brand new regulator.
Old Mar 19, 2003 | 07:08 AM
Maguire's Avatar
Born 2 Brap
ahh, i see now. Ditto on the filter location. Ive got one of those autozone brass reusable filters before my pump, and then just a regular paper one directly before the carb.
Old Mar 19, 2003 | 07:35 AM
jw36's Avatar
Nice, is it noisey? I have a holly pump on my '82 and it is very loud, it is bolted to the sub frame. just wondered if the mallory is any better just for future reference.
Old Mar 19, 2003 | 08:09 AM
Mallory is the BEST for the rex... NIIICE and QUIET!!!!
The best way to go..... Ask Mar3 about 'dem nasty carters
Laterz, Andrew
Old Mar 19, 2003 | 08:45 AM
inittab's Avatar
I read your email
Thanks! It's mounted pretty much where the original one was 'cept it's mounted to the underside of the car instead of the plate. I wonder if I should fab a bash plate?
Old Mar 19, 2003 | 08:47 AM
Pele's Avatar
Right near Malloy
Isn't the Mallory field rebuildable too? Or is that the Carter?
Nice location too. Right in front of where the Stock filter goes.
What happens if you change teh filter? Does the pump need primed so that it doen't just spin air, or is it self priming?
Old Mar 19, 2003 | 08:48 AM
inittab's Avatar
I read your email
Interesting take on it and the crud logic seems sound. The interesting thing about it is that the instructions that came with my Mallory says to mount the filter after the regulator. Hmmm, wonder why they say that?
Old Mar 19, 2003 | 08:49 AM
inittab's Avatar
I read your email
Yes, the Mallory is rebuildable.
Old Mar 19, 2003 | 08:50 AM
Pele's Avatar
Right near Malloy
Wow.. responded before I got done editing my post. THanks.
Old Mar 19, 2003 | 08:52 AM
inittab's Avatar
I read your email
It's self-priming.
Old Mar 19, 2003 | 09:18 AM
Pele's Avatar
Right near Malloy
It's self-priming.
Cool beans.. How much was it and from where?
Old Mar 19, 2003 | 09:43 AM
inittab's Avatar
I read your email
Well, it goes for $149.99 from Jegs but I got this brand new baby offa eBay for $61
Old Mar 19, 2003 | 07:48 PM
MIKE-P-28's Avatar
Driven a turbo FB lately?
oooops damn forum
MIKE-P-28's Avatar
Mine is bigger and has more fuel pressure, about 60 at 18 psi
Old Mar 19, 2003 | 11:26 PM
mar3's Avatar
Administrator
So mounting orientation doesn't matter? I thought the beast had to be up and down, course I haven't even opened the boxes to either one of my Mallory's to read the instructions. Hell, I don't even know which garage box they're in.....year and a half later in the new house and I still have boxes from the move...
Old Mar 22, 2003 | 02:39 PM
inittab's Avatar
I read your email
Boy I'm glad you mentioned that Mar3. It got me think'n so I emailed Mr Gasket (aka Mallory) and they said that it definitely has to be mounted vertically. So I remounted it on the vertical frame member. Fits pretty nice actually.
Old Mar 22, 2003 | 07:18 PM
mar3's Avatar
Administrator
Glad to be of help and you answered a question for me, too.....I've never actually sized up whether a Mallory would fit back there on the frame rail and now I know....the '83 is getting the conversion in April...
Old Mar 23, 2003 | 08:56 AM
smile444's Avatar
_________________________________________
What benefits/results have you had from the second filter??
Old Mar 23, 2003 | 11:48 AM
mar3's Avatar
Administrator
Oh, you little post *****... ...the filter at the back should be a pleated element style that is really unrestrictive. That means, by design, an element only stopping down to 40 microns or so. The pump has to draw from it. At the carb side, you pull the little filters from the top carb housing and the needle seat barrels, but now that means a filter outside of the carb good down to 10 microns to keep the junk out of the carb itself. If you're still stock, this is all overkill, however. Keep the internal carb screens and don't worry about a second filter...
