Radiator & Thermostat Question
Old Aug 20, 2001 | 03:24 PM
P.O.S. Racing's Avatar
Did Mazda use the same radiator in all the 83’ to 85’ Rx-7’s was there a heavy duty or –SE radiator?
What temperature thermostat do you run in your RX7?
Old Aug 20, 2001 | 06:14 PM
Pittdp's Avatar
When I was looking up my radiator I kept finding that the same radiator worked for 81-85.
Old Aug 20, 2001 | 07:31 PM
Johnny_84_GSL's Avatar
i think one size fits all for first gen. Rx-7's.......i run a 160temp t-stat
Old Aug 20, 2001 | 09:11 PM
stinkfist's Avatar
Learn to swim.
The 83-85 12a use a 2 row tall radiator while the GSL-SE uses a 3 row short radiator. 79-82 also use a 3 row short. however they are all interchangeable as long as you use the oilcooler that matches the radiator. The 3 row are far more desirable.
Use ONLY Mazda thermostats. You can get them in 160 deg, 170 deg, and 180 deg IIRC. The 160 is for best performance (power) while the 180 is for best fuel economy.
Mike
HDA
Nov 3, 2015 03:49 PM
LMBTG
Aug 15, 2015 01:43 PM
