ECU recommendations??? What's your opinion??
Old Aug 19, 2001 | 12:13 PM
psyco RX's Avatar
I've got all PFS upgrades on newly purchased FD: Intercooler, cold air induction, SS Catback, turbo gauge. Should I stick with PFS for the ECU or is their a better model out there. I'm not a auto technoid so I'm probably looking for the simplest/best unit to improve performance without too much stuff for me to screw up. Thanks for your comments guys.
Old Aug 19, 2001 | 01:35 PM
Pressurized's Avatar
Get either the Pettit unlimited or an Apexi' Power FC....stay away from the others if you plan to do a lot of mods. I made the mistake of getting an M2 ECU, not that it's a bad ECU, it' just that it won't handle a midpipe, streetport.....etc. I would sy if you're going to do mod as far as a single turbo, go with the Power FC, it can handle secondary injectors and all sorts of stuf....as for me, I'm at the end of the line with my ECU and I've only had it 2 months.....
Old Aug 19, 2001 | 01:43 PM
Mr. Mahtab's Avatar
If you with Peter farrel's computer, you can often find used ones on www.thepartstrader.com sometimes as low as $500
Old Aug 19, 2001 | 02:02 PM
Yeah, just make sure if you look into a Power FC that you have a dyno shop near you to tune it.....you can get maps that oter people have made, but just like hksFD3s said, not all cars are exactly the same.....
And if you decide to go with a pre-programmed ECU becuase you're not confident in doing it yourself, I still say look into Pettit...
Old Aug 19, 2001 | 02:11 PM
ErnieT's Avatar
Living life 9 seconds at a time
Peter's PMS is a nice unit, but it doesn't work on every RX7 the same. I had it for awhile, but got severe fuel cut. I spoke to Peter on this a few times as well as Dave at KD Rotary and they both said that for some reason or another some RX7 ecu's don't react well to the PMS and experience fuel cut with it.
I have since sold it and bought the Apex Power FC and can honestly say I love it. It gets rid of the 3k stumble entirely and makes the power band much smoother. And its not a piggy back system like the PMS, its a stand alone unit which takes the place of the ecu entirely. In fact, it takes a whole 3min. to hook up, just unplug your stock ecu and plug the Power FC in. Done....
And as mentioned before it can control larger fuel injectors as well as pulse width unlike the PFS PMC.
On a side not the PFS PMC is cheaper and does work very well for what it is and is a good start.
Ernie
Old Aug 19, 2001 | 02:22 PM
Bacon's Avatar
IRS 4 Life
i got the pettit unlimited///great ecu 15psi moded to hell and full rich on a/f...but if u got the $$ go apex pfc...im gonna be sellin my pettit in like 3-4 weeks to go apex...but im also goin single with bigger ingectors..
Old Aug 19, 2001 | 03:21 PM
psyco RX's Avatar
pettit or apexi -------- sounds good. Thanks for the advice.....I'm gonna check 'em both out. Sounds like the PFS unit is not the way to go.... THANKS
psycoRX
Old Aug 19, 2001 | 04:26 PM
JoeD's Avatar
i think the M2 stage III can handle a midpipe. thats what turboVR6 is running.
Old Aug 19, 2001 | 09:13 PM
Mach2's Avatar
JoeD,
M2 advises not to use it's ecu with a MP, and especially not with a street port. As for running the Pettit Unlimited with MP and street port, it's possible and I've done it for some time with no side effects. I spoke to Jeff at Pettit and he said the ECU would work great with the MP and should work with the street port(depending on how aggressive). I think that the Pettit ECU is the best for the money, period!! If you have the extra $$ though go with the PFC as you "will" decide to upgrade even more and you'll be able to do so with it!
Old Aug 19, 2001 | 10:33 PM
Rix7's Avatar
Why hasn't anybody mentioned Haltech?
Old Aug 19, 2001 | 11:19 PM
Bacon's Avatar
IRS 4 Life
well b/c haltec costs as much if not more than pfc, is not plug and play..would take better part of a weekend to install...and with his mods he could get just as much hp with less cost and hassle...im not knocking haltec in any way...i even planned on doin it till i weighed the costs out...to get a haltec set up to what i wanted..i could do with the pfc in half the time and get similar results...
xs got 477 out of a single and pfc...dont think id ever need more than that
+pfc runs the omp..haltex either u got to premix or buy mechanical omp=$$
Old Aug 19, 2001 | 11:49 PM
Rix7's Avatar
More often than not the best always costs the most $.
Old Aug 20, 2001 | 12:10 AM
Bacon's Avatar
IRS 4 Life
just bustin your *****, so ur talkin abt a motec if i remember right is like 4k ++install.....??? right? well that is the most expensive
...personally ill spend 1500 and go pfc..
had the pettit and ive reached the limits of the stock fuel system
pettit can't acomdate 1600's so i have to go standalone/pfc
but like i said haltec will cost abt equal but then u got to throw in mechanical omp(dont know cost but is over 500 b/c ive seen used ones gor for that)--pfc runs the omp... then unless u install urself u got to pay for that(pfc if it takes u more than 20 min to install ur doing something wrong)
but back to the thread, for his mods and unless hees got plans to go all out..an upgraded ecu or pfc is the logical and economical thing to do...
i dont know abt u but 477 at the wheels is damn good for a streetable car...and if i ever have the bug to go faster...ill have the $$ to go haltec...but id prob end up with a 20b if i need more than 477at the wheels in astreet car...
but spend ur $ how u want...most expensive
Old Aug 20, 2001 | 06:33 AM
psyco RX's Avatar
what end results can I expect from the apexi pfc vs. oem? Do I need to dyno the car or will I be ok w/ just plug and play??
Old Aug 20, 2001 | 08:13 AM
croman's Avatar
How about the RPRotary Performance ECU
rx7.com - RP Rotary Performance ECU... I hear that's almost the same as the Pettit ECU... Any problems with that one...?
Old Aug 20, 2001 | 09:01 AM
bploz RX7's Avatar
Bacon... do you have a buyer for the Pettit yet?? if not send me a pm
Old Aug 20, 2001 | 10:53 AM
Bacon's Avatar
IRS 4 Life
sorry its 460.7 my b on a to4s full boost at 3800
heres the thread
https://www.rx7club.com/vforums/show...&threadid=8808
ohh 460.7 is at 16.4psi...nothin 2 crazy i dont think...
Old Aug 20, 2001 | 06:23 PM
P-FC
Personally I'd go withthe P-FC. In fact, I did. The existing ECU, and all rechipped versions are 8 bit, the 16 bit P-FC controls better IMHO. The biggest limits withthe P-Fc is it does not support extra injectors or a wide band O2 sensor. So if your planning big HP or need to retune often, then something more than the P-FC is needed. If you have that kind of money, then you could always just throw your P-FC in the garbage just to underline the fact you got bank.
I picked up mine used for $950 w/ shipping. I think it's better than any reprogrammed unit.
Good luck!
Old Aug 20, 2001 | 08:06 PM
suganuma's Avatar
no
are y'all talkin RWHP or flywheel HP here???
and as far as big power from an 8 bit retuned ecu like the pettit unlimited check out www.rx7s.com ...click on customer cars
youll find...
Anthonys 1993 Rx7. 386 rear wheel horspower. Best quarter mile time of 11.26@119.6 on stock twins and pettit unlimited ecu
i myself have a g-force unlimited ecu.....its a great one, but im thinking of going pfc or haltech.....im having real trouble deciding because of the ups and downs of both.
Mrmatt3465
Interior / Exterior / Audio
Sep 17, 2015 01:28 PM
mulcryant
Sep 9, 2015 05:24 PM
