bucking car
Old Aug 19, 2001 | 08:07 AM
bgarneau's Avatar
bucking car
My car have another probleme again, It have run only five day corectly. When it's cold it's run okay. After 2 miles the engine buck and it's run only between 1000 and 2000 rpm. I have change the fuel filter, the Treading coil, and the spark plug. What can i try i have another car for parts but i have no idea. Thanks!
Old Aug 19, 2001 | 08:10 AM
HAILERS's Avatar
HAILERS
Ol Buck needs the TPS swapped out with your other one. Then adjust it. As good a wild guess as any.
Old Aug 19, 2001 | 08:50 AM
punkncat's Avatar
Does it do this in correlation with coming on or off the clutch? Or does it intensify when you let on and off the gas pedal? You may want to check your rear tranny mount, and U-joints.
Old Aug 19, 2001 | 04:38 PM
bgarneau's Avatar
The tps is not the same model between my to car. i have removed, clean it and réinstall, and the car run a little bit better. I will going to ma mazda dealer to by one or does somebody know a better place to buy it! Thanks!
Benoit Garneau
Old Aug 19, 2001 | 07:31 PM
HAILERS's Avatar
HAILERS
I'd hold off buying one from the dealer on the guess work of somebody on the web. You really need someone who works on these cars to actually touch the car. If you do the tps, try the wrecking yard first. Big buck item for so little.
Old Aug 26, 2001 | 11:29 AM
Turbo7's Avatar
I had a very similar problem and it was the TPS.
Any good rotary/mazda mechanic will have a device to check if your TPS is faulty or not.
How much do you guys in the US pay for new and 2nd hand TPS's?
fastrx7man
33
Sep 2, 2015 09:42 PM
cam_7779
Aug 18, 2015 07:48 AM
