FD calipers on S5 TII?
Old Feb 24, 2003 | 08:23 PM
Cheers!'s Avatar
Former Rx7 *****
Current Car
one noble white 1989 mazda Rx-7 TurboII
with 112,000 miles
What is needed?
Brake Job,
front and Rear pads and rotors
What i want...
rebuild my calipers at the same time.
Question:
Will the FD Brake Calipers (Front and Rear) bolt right up to my S5 TII? It has the vented rear rotors and vented front rotors with 4 pot calps.
Thanks
Old Feb 24, 2003 | 08:34 PM
silverrotor's Avatar
Someone hear has done this but the other way around on their FD.
Old Feb 24, 2003 | 08:40 PM
Cheers!'s Avatar
Former Rx7 *****
ya... that was BATMAN
but i'm not sure if he used the rears also
Old Mar 27, 2003 | 04:02 PM
Barwick's Avatar
SCCA Rookie
I'm pretty sure they use the same pads, so I would think it's possible.. but they don't use the same rotors do they?
Old Mar 27, 2003 | 04:46 PM
Rx-7Addict's Avatar
Rotary Powered
The T2 has great brakes
4-piston front calipers, ~12 inches all around
not much to improve upon really
Old Mar 27, 2003 | 08:33 PM
Cheers!'s Avatar
Former Rx7 *****
the front rotors are the same as FD... that is why you see people buy brembo x drilled front rotors (genuine ones, not ebay crap)... but the rears, brembo does not make a set for the FC and the FD don't fit... thus you stuck with either blanks or some other make
Old Mar 28, 2003 | 12:41 PM
turbojeff's Avatar
Do it right, do it once
Rotors are not the same. FD rotors are bigger front and rear than any FC rotors.
The caliper body is different. FD calipers will bolt right up to any 4 piston FC.
I think the bolt holes that hold the caliper on the FD are moved farther away from the spindles. I don't think the FD rotors will be a bolt on fit. Haven't tried this though.
Jeff
angel824
Mar 17, 2019 09:44 AM
Vartok
Sep 24, 2015 02:20 PM
04G35S
Sep 9, 2015 07:05 AM
