what puller do i need for flywheel??
Old Feb 22, 2003 | 09:08 PM
i have an 83 engine and i need to remove the flywheel.
i need to know if i can use a gear puller that opens up to 6 inches.. can i just pull the shaft through the engine to remove the flywheel?? if not and you know what and where to get a flywheel puller please inform me!! thanks JC
Old Feb 22, 2003 | 09:36 PM
once the nut is off (hardest part) any puller medium-sized will work, don't quote me
Old Feb 22, 2003 | 10:08 PM
well i need exactly what i need
Old Feb 22, 2003 | 10:20 PM
Siraniko's Avatar
RX for fun
No need to get a puller; instead get a good size rubber mallet. Just loosen the flywheel nut, give it a good whack and the flywheel will come loose. The nut will keep the flywheel from falling on your chest while your under the car.
rhinor61's Avatar
Well, thread the nut back on part way, take a 2lb ballpeen hammer and smack the edge of the flywheel missing the ring gear. Tada.. should come off in a few smacks, ask how is this posible, cause the flywheel is sitting on a tapered shaft. I have tore up many rental heavy duty pullers with no luck.
John
Old Feb 22, 2003 | 10:21 PM
Sammymatik's Avatar
Your only gonna need a puller if the flywheel is really stuck on there. Try it with a dead blow hammer first. This has worked for me on the last 4 engines. Although I do member' someone who was having a hell of a time.
Old Feb 22, 2003 | 11:34 PM
Rx7carl's Avatar
Airflow is my life
Where are you? Near Orlando? Bring it here and Ill bust it off!
Old Feb 22, 2003 | 11:36 PM
no im in navarre near pensacola florida!! so i can hit with a hammer but i still need the puller for futre where can i get one??
Is the gear puller from sears going to work??
Old Feb 22, 2003 | 11:40 PM
Rx7carl's Avatar
Airflow is my life
Gear pullers wont do **** for a flywheel. Put the nut back on a couple of threads like was stated earlier. And do someting like this.
And once its nice and tensioned up, whack it with a mallet. When its loose youll know, so will your neighbors.
Old Feb 22, 2003 | 11:44 PM
so how do i set that up??
Old Feb 22, 2003 | 11:45 PM
hey while i got your help do you have a pic of all vaccum hoses hooked up coorectly on both sides of carb.??
Old Feb 22, 2003 | 11:51 PM
Rx7carl's Avatar
Airflow is my life
Well the bar goes across the flywheel, the bolts thread in, and the little block (any piece of metal will do) acts as a spacer. Tighten the bolts good and tight to put pulling tension on the flywheel. It might come off right there, if not, a few whacks with a mallet should do it.
Old Feb 22, 2003 | 11:52 PM
Rx7carl's Avatar
Airflow is my life
vacuum hose diagram is under your hood. Why do you need it?
so did you have the pic of vaccum hoses correctly hooked up??
Old Feb 22, 2003 | 11:54 PM
Rx7carl's Avatar
Airflow is my life
Oh sorry no. But Im working with someone who is working on a colorized diagram. Hopefully this week itll be done.
Old Feb 23, 2003 | 01:21 AM
Kill No Cone's Avatar
Just use a hammer and hit it hard by the ring gear (not on the ring gear). I have spent days trying it the other way, when just a hit with a hammer did it.
Old Feb 23, 2003 | 10:38 AM
MIKE-P-28's Avatar
Driven a turbo FB lately?
turn the nut a few threads, hit it with a large hammer, turn 1/8 turn, hit it again, turn , hit, keep repeating. Dont hit the teeth... It will come off... I never had a problem with this procedure...
The aforementioned one, I have stripped and broke bolts off doing that...
Old Feb 23, 2003 | 10:47 AM
umm what if the flywheel wont turn?
Old Feb 23, 2003 | 11:35 AM
MIKE-P-28's Avatar
Um then you hit it in different places. Turn the engine stand ect...
Old Feb 23, 2003 | 06:31 PM
Rx7carl's Avatar
Airflow is my life
On the diagram, PM FJ, hes the one doing it.
Old Feb 23, 2003 | 07:39 PM
rx7carl, that is bad ***. I had to take the flywheel off a t2 engine. Had a screw driver wedged in it to keep the flywheel from spinnin, a 6ft breaker bar with me jumpin on it, and a friend standing on the side of the engine trying to keep it from rollin... Got it open tho....
LongDuck
Oct 7, 2015 08:12 PM
