rear end/driveline clunk
Old Aug 17, 2001 | 08:21 AM
4cefed7's Avatar
Angry rear end/driveline clunk
after a dismal night at the strip, my car is clunking. If i put it in gear and let out the clutch at normal speed it makes a thud noise. if i let the clutch out real easy(super slow) it doesnt do it.
I put the car up, and rocked it back and forth. the diff. was visably moving. is it my mounts or something else?
Old Aug 17, 2001 | 11:44 AM
MikeL's Avatar
Front differential mount. Mine did that the second time I went to the track. It was hard to see where it was broken unless looking at the mount while rocking the diff or using a long screwdriver to pry on the mount.
The mazda dealer changed mine in about 15 minutes without removing anything.
Mike
Old Aug 17, 2001 | 03:34 PM
4cefed7's Avatar
well at least that is some good news. If i dont get taken to the cleaners on it.
Old Aug 17, 2001 | 03:47 PM
4cefed7's Avatar
Mazda wants 300$ for labor. what a bunch of asses
Old Aug 17, 2001 | 04:00 PM
4cefed7's Avatar
Mike what did they charge you for the part?
Old Aug 17, 2001 | 04:08 PM
MikeL's Avatar
I paid $238 total. The part was about $130. I think Mazdatrix sells it for less.
Any shop or you can change that thing. The mechanic used a swivel thing on a rachet. He had a hard time finding the right way in and the right combination of extention(s) but, he did it. It was on a rack though. It might be harder if you lay on the ground to do it.
Mike
Old Aug 17, 2001 | 06:20 PM
4cefed7's Avatar
i found the part, it looks like a total bitch to get to but not impossible.
Old Aug 17, 2001 | 07:01 PM
MikeL's Avatar
Be sure that's actually the problem. It should be but, there are other bushings back there also. I crawled under and could barely see that the rubber was broken away from the metal. I pried on it and saw the rubber move away from the metal.
autoxer
21
May 22, 2019 04:07 PM
Michael Mansour
Aug 18, 2015 03:13 AM
