Screwed up idle
Old Aug 17, 2001 | 06:15 AM
bobr's Avatar
Chris,
Lots of good idle info on this page. One of the other guys posted it here before when I had some idle problems.
http://www.nellump.com/peri/epi/firs...gslseIdle.html
Old Aug 17, 2001 | 07:14 AM
MasteRX's Avatar
More Than Meets the Eye
TPS could defenitely be the culprite. I would first check to see if it is set correctly though. http://www.iluvmyrx7.com/Technical_I...ice_manual.htm
Here is a factory manual online. The factory manual has a good method for checking if the TPS has gone bad. The portion you want is Fuel and Emissions Control Systems. Besides the TPS I would check for vacuum leaks, also I would check a few other sensors in that chapter of the manual I listed above. All you need to check most the things is a multimeter.
For TPS adjustment, there are countless FAQs on how to do this. Just remember one thing, many FAQs will say to build a test lamp out of two light bulbs, I do not recommend this method as the light bulbs draw too much current. The best (in my opinion) and easiest way is to use a test lamp out of LEDs. You can either but the factory Mazda test lamp from mazdatrix.com, or you can build your own. There is also a method using multimeters, but you need two of them, and it seems like more of a pain to me, not to mention more expensive if you have to buy another multimeter.
DerpyToast
14
Nov 23, 2024 05:19 PM
ZacMan
Sep 19, 2015 09:20 PM
RotaryBobby
Sep 10, 2015 01:33 PM
