GT35/40 dyno curves
Old Feb 17, 2003 | 01:16 AM
Rx7-AIII's Avatar
GT35/40 dyno curves
Hi
Sorry to bring this one up again but I can not find any of the dyno plots on the site anymore. I took my car for a dyno run. GT35/40 with the 0.82 exhaust side. There is a slight constriction in the exhaust as well due to a too small gasket. I did a run at 13 psi and got 310 rwhp. I suspect I will see 350 rwhp @ 15/16 psi which was what I was hoping for. I am interested to see how this compares to other peoples figures at different boost pressures and exhaust trims.
Thanks
Old Feb 17, 2003 | 06:51 AM
ZoomZoom's Avatar
SEMI-PRO
my GT3540 with a 1.06 A/R put down 319hp @10psi and 340@12 psi. Stock motor, GReddy 2 row front mount intercooler. HKS twin power ign, Power FC ECU, 1600cc sec inj, nippon Supra FP. SX FPR. DP, Midpipe, Catback.
Old Feb 17, 2003 | 12:27 PM
Rx7-AIII's Avatar
Thanks for that. Do you still have a copy of the dyno plot that you could email me?
Martin
sintler@lineone.net
Old Feb 17, 2003 | 08:17 PM
ZoomZoom's Avatar
SEMI-PRO
Martin
sintler@lineone.net
I pick the car up from the shop on Friday. Will have the dyno sheet scanned and posted.
Old Feb 18, 2003 | 12:48 PM
Rx7-AIII's Avatar
Thanks I will look forward to seeing it.
Old Feb 19, 2003 | 12:51 PM
importboi22's Avatar
Hks Ownz Me (
thats weird there some guys with the apexi rx6 putting down high 300's at 13-15psi? i thought the gt35/40 was a much better choice for high HP output, you guys are making similar power whats up with that?
Old Feb 19, 2003 | 01:35 PM
Rx7-AIII's Avatar
Dyno and boost?
Old Feb 19, 2003 | 01:49 PM
es's Avatar
es
340@12PSI on the stock block is a pretty good number. I could easily read 380-390@15PSI with that dyno plot, and again, that's on a stock motor. Push that air through a ported motor & you're talking about 420-440@15PSI. I don't see anything substandard with those numbers...
I'd also like to mention that the GT3540 has a higher boost potential. You can produce >20PSI with that turbo where the RX6 is going to be topped at ~17PSI.
Old Feb 19, 2003 | 01:55 PM
Hks Ownz Me (
oh ok thanks for the clear up..
Rotate86
May 18, 2018 02:44 PM
eddierotary
Engine Management Forum
16
Oct 4, 2016 08:22 PM
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
BLUE TII
Sep 26, 2015 10:12 PM
