fuel, electricle.
Old Aug 16, 2001 | 10:02 PM
kliftin's Avatar
fuel, electricle.
hi, I have the wiring harness installed in my 89 gxl now. The problem now is that it cranks over but does not start. Im wondering if im not getting any fuel. How can I check for fuel with a tester light. Like at the egi box or anything. Any info would be helpful. thnx
Old Aug 16, 2001 | 10:09 PM
HOZZMANRX7's Avatar
Driving RX7's since 1979
Check and make sure you didn't hook up your source and return fuel lines backwards. Been there, done that. I'm sure I'm not alone. :-)
Old Aug 16, 2001 | 10:19 PM
kliftin's Avatar
hey
Im sorry but wheres that. Hey, also I Relieved the pressure from the injectors when I had to take the rail off. Do I somehow need to recharge or pressurize the system.
Old Aug 16, 2001 | 10:22 PM
HAILERS's Avatar
HAILERS
Pull the plugs and crank the engine over fifteen seconds. Should get a fuel mist out of the plug holes. Small danger here, but not unacceptable. No fuel mist? Jumper the yellow check connector on or near the r/h strut tower, turn the key to the on position but do not start the car. Break a connection on the fuel rail and see if it squirts. Talking one of the banjo bolts. Or get a can of starter fluid and squirt in the intake. If car momentarily turns over its probably a fuel issur. If not an electrical/.
Old Aug 16, 2001 | 10:29 PM
HOZZMANRX7's Avatar
Drivers side of the engine bay. The rubber hoses that run from the firewall group of 2 pipes (one fuel supply, other fuel return) to the under EFI assembly of 2 pipes.
Old Aug 16, 2001 | 11:31 PM
kliftin's Avatar
yo
thnx alot.
rgordon1979
40
Mar 15, 2022 12:04 PM
bryancmatthews
Power FC Forum
14
Oct 5, 2015 08:49 PM
sherff
Sep 12, 2015 12:22 PM
Steven_McKinley
Sep 5, 2015 10:48 AM
