Oil Leak - Where can it be coming from?!
Old Feb 14, 2003 | 06:32 PM
Newbie
I have an oil leak but can't figure out where it's coming from. It spurts out whenever I accelerate. At first I thought it was the line to the turbo, but replaced that and it's still leaking. Anyone have any experience with this problem?
Old Feb 14, 2003 | 11:45 PM
paw140's Avatar
Ummm.... look under the car . Could you be any less specific? In what general area is the leak coming from?
Old Feb 15, 2003 | 06:12 AM
maxcooper's Avatar
WWFSMD
Rear main seal, oil filter pedestal, turbo oil lines, etc. can all leak. You've got to take a look to see where the oil is coming from.
-Max
Old Feb 15, 2003 | 10:55 AM
Rx7pimpin's Avatar
Try the oil metering pump lines..
Old Feb 15, 2003 | 11:00 AM
gohorns's Avatar
Is a little leak in these areas normal. FWIW I have seen a car with no leak at all.
-Max
Old Feb 15, 2003 | 12:52 PM
Shinobi-X's Avatar
Sensory Experience
Oil leaks suck. I have one myself, and I know it's because of the turbos. You can see small amounts of oil in the intercooler elbow. The oil pan is also soaked with a layer of oil. There is so much, I can't pinpoint where it is coming from yet. As soon as the weather clears up, I have to find it.
Old Feb 15, 2003 | 02:44 PM
SPOautos's Avatar
Hey, where did my $$$ go?
Oil in your IC pipe doesnt mean your turbos are going bad. There is a vac line that runs from the oil filler neck to the primary turbos intake pipe. Its one of those 2 lines on that intake pipe right in front of the turbos.
Anyway, you get oil blow by into your intake system from that vac line.
Now, this isnt to say your turbos arent bad, just that oil in the IC pipes is not really a hard sign of turbo faliure.
STEPHEN
Old Mar 16, 2003 | 09:52 AM
gohorns's Avatar
anyone know the rear main seal part #
Old Mar 16, 2003 | 10:19 AM
apneablue's Avatar
No, but I know you get the rear main seal set from www.rx7.com (Rotary Performance) for about $20. Oil leaks suck...Mostly the smoking and the smell
Old Mar 16, 2003 | 03:19 PM
Dougie_fresh_007's Avatar
yeah i still have my oil leak, and i cant find it for the life of me, but its under teh car.............somewhere
Old Mar 16, 2003 | 03:21 PM
apneablue's Avatar
One of the best ways I got to find mine was to take it to a friends garage, stick it up on the lift and spray it fown with degreaser then wash it off then wait for it to start trickling again...somewhat helpful but not always
Old Mar 16, 2003 | 03:40 PM
i want a friend with a lift.........
Old Mar 16, 2003 | 04:23 PM
JONSKI's Avatar
5yr member, joined 2001
Did you over-fill it with oil?
Microtech
30
Apr 23, 2016 06:37 PM
Cameron38
Aug 19, 2015 06:08 PM
sypath
Aug 16, 2015 12:06 AM
