Worrying brake rattle
Old Feb 14, 2003 | 05:38 PM
PaulFitzwarryne's Avatar
Apprentice Guru
My car has a slight rattle noise at the front, the worry is the moment I touch the brake pedal it stops.
I checked the brake pads and rotors. Nothing feels loose on them. Being brake relatedi am worried there is a potential safety problem. Any ideas?
Old Feb 14, 2003 | 06:11 PM
DONNA's Avatar
went thru this too,,,have you tried pulling up the emergence brake when u here it,,,mine was the cable was loose,,,,,may be the same with yours...thought it was my front pads,,,,good luck
Old Feb 14, 2003 | 07:37 PM
DONNA's Avatar
about half a click, b4 i get flamed...
Old Feb 14, 2003 | 07:56 PM
specRX7_22's Avatar
my first thought would be the rotors are loose. i think this because you say when you brake, it stops. maybe when you brake, the pads hold the rotor tight which is why it stops. a good way to make sure your rotors are seated correctly is..... take off the dust cap and everything else until you get to the nut. torque the nut to 50 lbs, back it off again (to make sure its seated), and then torque it to 20 lbs. that should be perfect.
Old Feb 15, 2003 | 06:49 AM
inittab's Avatar
I read your email
I have a click, click, click noise coming from my left front brake pads. There are two things causing this, one, my rotor is slightly warped and two, the pad is too small for it's carrier. I even have the retainer clips in there. The pads were cheap and I think they might be out of spec. The situation doesn't worry me but it's damn annoying.
Old Feb 15, 2003 | 12:12 PM
AdrenalifeRX7's Avatar
Are you gonna shift?!
could the rotors be warped?
chiefmg
Sep 10, 2015 07:46 AM
Tem120
Sep 7, 2015 09:53 AM
ZaqAtaq
Sep 5, 2015 08:57 PM
Frisky Arab
Sep 4, 2015 06:17 PM
