Push Button Starter
Old Aug 16, 2001 | 01:27 PM
jizzajuice's Avatar
Cool Push Button Starter
Yo, I've been reading some posts and some people in the third gen sectio have been ranting and raving about the push button starter. I think it'll be a great addition to a second gen too! For those of you that have done this, where did you place the push button starter? and also HOW did you wire it up? A diagram or ANYTHING would be much help!! Thanks!
Peace,
AJ ^_^
Old Aug 16, 2001 | 05:38 PM
jizzajuice's Avatar
Exclamation
_bump
Old Aug 16, 2001 | 09:21 PM
rx7_ragtop's Avatar
From: Ft. Worth, Texas, USA, Earth, Solar System...
Ummmm... why?
Brad
Old Aug 16, 2001 | 09:24 PM
Christopher's Avatar
Because obviously he wants to.
Old Aug 16, 2001 | 09:27 PM
TonyTurboII's Avatar
Glock Lover
Re: Push Button Starter
Peace,
AJ ^_^
Yeah, I was also thinking about this mod, and putting it in my Cig lighter. Or in my Ash tray, as I dont smoke. It would be a nice place to hide it. Im sure wiring cant be that far off from FD, basic electrical know how. There should be a link to a site in the 3rd gen forum, as I have seen a page with instructions on how to do it. Read the instructions, look at a 2nd gen wiring diagram, and figure it out.
Old Aug 16, 2001 | 09:38 PM
BOOSTD 7's Avatar
Persona non grata
I'm probably going to do this myself... Not sure where I'll put it.
Old Aug 17, 2001 | 12:14 AM
push button starter would be wicked! But my 7 is pretty fussy starting.. especially the first time each day... I don't think a push starter would work for mine.... And I suck with electrical stuff... I try not to touch my battery, because I will probably electricute myself haha
Old Aug 17, 2001 | 01:48 AM
hypntyz7's Avatar
Couldnt be simpler. This is also a good fix for auto to manual conversions to bypass the neutral/park switch, and people who dislike the clutch switch.
You need to get 12v switched(key) power from somwehere, probably the fusebox is the best place. Use a dmm to isolate a terminal that is on when the key is on, off when the key is off. Run a wire from there to whereever your switch is. Run another wire from your switch to the starter trigger(top slide connector, small wire). Take the stock slide connector off and leave it hanging or tie it up. Now hook up your 2 wires at the switch, then hook up the wire at teh fusebox. You're done.
Old Aug 17, 2001 | 03:21 AM
kliftin's Avatar
hey
wow, couldnt be easier. Do you have any pics.
Old Aug 17, 2001 | 08:51 AM
hypntyz7's Avatar
No, not really, I did this on an old Toyota Celica that I once did a 5sp swap to. ITs a good way to bypass the safety switch crap.
Old Aug 20, 2001 | 10:24 PM
jizzajuice's Avatar
Talking
alright can anyone find that 3rd gen post about the push button starter with the charts and eveytrthing? I've tried but cant seem to find it. I'm gonna try to lay out an outline first and see if it's feesable with the time constrainst i have. in any case, any help would be much appreciated thanks!
Peace,
AJ ^_^
Old Aug 21, 2001 | 01:43 AM
hypntyz7's Avatar
Again, here is your outline:
1) isolate SWITCHED 12v+dc terminal in fusebox suitable for running a small wire out of, use a slide connector to fit the fusebox terminals
2) run this wire to wherever you want your switch
3) run another wire from where you want your switch, down through the firewall or through the shifter assembly back to the actual starter.
4) On the solenoid(small cylinder on top) there is a small slide connector. disconnect it.
5) connect the wire you just ran to the terminal on the starter you just exposed. use a slide connector similar to what you removed.
6) make the connections at the switch
7) make the connection at the fusebox.
8) remember that the car will now turn over anytime the switch is on. No park or clutch requirements.
how much more detailed of an outline would you like?
Old Aug 21, 2001 | 11:10 AM
jizzajuice's Avatar
Hey, that's an awesome outline. Thanks a lot! I'll probably try it out within the month that's if it still sounds like a project I can do myself. In any case, I really appreciate you guys helping me out!
Peace,
AJ ^_^
Old Aug 21, 2001 | 12:24 PM
kliftin's Avatar
thnx
Thnx.
LongDuck
Oct 7, 2015 08:12 PM
Sh00bs
Oct 1, 2015 11:57 PM
rx7inoregon
Old School and Other Rotary
Oct 1, 2015 12:44 PM
