Is there a missing piece here???
Old Aug 16, 2001 | 12:54 PM
Inca's Avatar
Question Is there a missing piece here???
With this mod list on a 93/FD/Touring correct me if I'm wrong but doesn't it need a new ECU?
Factory replaced engine with 35000 miles on it, runs 13lbs of boost in 3rd and 4th gear.
Performance parts:
Greddy stock mount intercooler
Greddy hard pipe kit
Greddy pulley kit (air pump removed)
Trust cat back exhaust
HKS FCON/FCD/timer/boost gauge
HKS blowoff valve
HKS downpipe and highflow cat
5Zigen white 17", 6 spoke wheels with Bridgestone SO2's
Aspec racing clutch (200 miles on it)5th gear syncro replaced with clutch
Peter Farrell intake
GAB strut tower bar
Tokico 5 way shocks
H&R springs - 1 1/4" lower than stock
Eibach front and rear sway bars
Nology plug wires
momo shift ****
Thanks for you input guys and gals!
Much appreciated.
INC.
Old Aug 16, 2001 | 01:26 PM
Inca's Avatar
Okay, tell me if I'm right too.
New ECU or Not?
Thanks.
Old Aug 16, 2001 | 01:35 PM
Neo's Avatar
Neo
Cool
Inca,
It's got one of those small adjustment computers (FCON?).
As far as I can tell, that FD is/should be running a fully programmable system.
Popular one on the form is the Apexi PowerFC. The Haltech is another.
Without a computer that engine will blow in dew time.
Old Aug 16, 2001 | 01:48 PM
Inca's Avatar
I guess this means I'll be looking at a couple bucks to replace.
Crap!
Thanks for the feedback Neo.
Inc.
Old Aug 16, 2001 | 01:56 PM
puma's Avatar
canadian monster
well if you have an F-con, the fuel map is reprogrammed so you shouldn't blow the engine.
Did you just bought that car?
puma
Old Aug 16, 2001 | 02:34 PM
luneytune's Avatar
ECU?
I would add a air/fuel meter and you can then be sure your not running lean - the ECU will not retard your ignition past 4000RPM based on the knock sensor, a PFC is a faster computer and can retard above 4000 and get rid of the 3000 RPM hesitation problem. The FCON can only control and richen up to a point when your injectors are running at 100%. I didn't see upgraded injectors in your list? IMHO
Old Aug 16, 2001 | 03:28 PM
Inca's Avatar
Hey,
Puma: I actually haven't purchased it yet, but I'm looking at it this weekend.
I have a bit more info from a few emails with the owner.
I asked: Hesitation at 3000 RPM?
Owners answer: Only when cold, and not at all when the FCON is activated. But that is not needed because I have a cat on the car. I virtually eliminated that hesitation by attaching a ground strap to the battery, so I think by cleaning the terminals again it will remedy it.
I know the ground would help to eliminate the hesitation, but the other stuff????
The mods look fairly complete (for reliability) with the exception of this and maybe vac. line replacements.
Ideally don't want to get into too many fix/replacements right off the back. So it's kind of this little bugger or a stock version of it that I'm choosing between
It's always going to be a tough choice I suppose.
Thanks guys.
Old Aug 16, 2001 | 04:40 PM
puma's Avatar
canadian monster
is it a silver one that was on sale on trader.ca a month or two month ago?
I believe he has a web page to **** it, am i right?
Old Aug 16, 2001 | 04:46 PM
puma's Avatar
canadian monster
oups sorry, just read the mods, this is not the same car
Old Aug 16, 2001 | 05:11 PM
neevosh's Avatar
The Dude Abides
You can't be running a cat and not have the airpump hooked up. It's not good for it and it won't do anything at lower RPM's. And since when did HKS make a high flow cat?
Old Aug 16, 2001 | 08:20 PM
Hyperite's Avatar
Vagina Junction
You can run a cat w/o airpump. There are cats nowadays that don't have the inlet for secondary air injection. They do it chemically. Expensive cats though. Dunno if HKS makes it.
~Tom
Old Aug 17, 2001 | 12:53 PM
Inca's Avatar
Okay this car seems to be getting sketchier by the minute. I think I need to check up on the HKS cat.
Puma: I found it on thepartstrader.com, but he has just listed it on the autotrader.ca. It's the black one with the mod list. This unorthodox mod list worries me.
I'm not sure right now; it's either this one or the stock Montego blue one listed under the owner name Kerry - both on autotrader.ca
Inc.
Old Aug 17, 2001 | 01:03 PM
Neo's Avatar
Neo
Cool
It looks to me like the Montego Blue is the one that you should be looking at. It looks like it's been really well maintained.
The others I looked at autotrader.ca don't look all that well. Maybe the red one but not the black one with a bit of mods done to it.
Have you seen the Blue one up close and personal?
It all depends on how the car looks like up close. Pictures can only do so much....
Old Aug 17, 2001 | 01:43 PM
Inca's Avatar
Hey Neo,
Thanks for the guidance man. I had an appointment a while ago, but it got cancelled and I've been holding off on rebooking to wait for my bank to answer me about financing. I should know today what the finance will be. They've been taking their sweet time about it!
I hope I can talk the guy down a bit, and then do a few mods with 2 or 3K before storing it for the winter.
Here's a pic of the engine from the black one. This was my first warning signal I think.
Oh I wanted to ask you if your first name is Chris? Do you work in Etobicoke? Not sure if I know you or not.
Inc.
Old Aug 17, 2001 | 02:00 PM
Neo's Avatar
Neo
Cool
PM'd you Inca
Old Aug 17, 2001 | 02:56 PM
Inca's Avatar
pic
Old Aug 17, 2001 | 09:16 PM
puma's Avatar
canadian monster
ok now i know i am dumb but what the hell is a piggy back?
thanks and sorry for my ignorance but i had to ask
puma
