Changing Manual Tranny Fluid on FD
Old Feb 12, 2003 | 06:40 PM
DCrosby's Avatar
No it's not Turbo'd
How often do you change the transmission fluid on a manual tranny in an FD RX7 ??
Derek
Old Feb 12, 2003 | 07:08 PM
Crash's Avatar
Every 15k miles. make sure you use synthetic makes a noticable diffrence on the smoothness whne shifting.
If you just bought the car it's a good idea to go ahead and change it. Not a hard job at all.
Old Feb 12, 2003 | 08:33 PM
airn's Avatar
what fluids are best
Old Feb 12, 2003 | 09:20 PM
skunks's Avatar
I'm a CF and poop smith
redline! either MTL or MT-90, i already did a write up on how to with lots of pics, unfortunatly, the search function does not work for finding it for me after they reloaded the server or something, it had pics of my ramp setup, pics of where the bolts are and everything. The most important thing is to just make sure when you are doing it to be able to get the fill plugs off first before you start to try to get the drain plugs off (same exact thing goes for the rear diff!!!) if you dont do this first, your gonna be stuck with one dead FD cuz your gonna have drained all the fluid out and no way to refill it!!!
Good luck dude, and its super easy, this is right up there with the fan mod or changing oil! there is no excuse not to do this
Old Feb 12, 2003 | 09:31 PM
how much does it cost for a bottle of redline?
Old Feb 12, 2003 | 09:46 PM
RX7SpiritR's Avatar
The Spirit of FLUFF!
I used Mobil 1 full synthetic 75w 90....and it works wonders! But just to make sure, 3 quarts is enough right? I have a '93, because I know there was a slight difference in the capacity.
Old Feb 12, 2003 | 09:48 PM
skunks's Avatar
cost about 8 bucks per quart for redline. IDK if it really helps or anything, I just know that I use it and mines is doing just fine
Old Feb 13, 2003 | 04:06 AM
maxcooper's Avatar
WWFSMD
Tranny capacity is 2.6 qts, diff is 1.4. Best to get 5 qts if you are doing both in case you spill a little. 3 should be enough for just the tranny and a few minor spills.
-Max
Old Feb 13, 2003 | 05:43 AM
airn's Avatar
thanks
Old Feb 13, 2003 | 07:38 AM
HeX's Avatar
HeX
01010010011010110
If you use synthetic, make sure you use a clean-burning/ashless type. Why? Synthetic holds up better so it doesn't all get burned up. Meaning it will likely leave more carbon build-up which is deadly to a rotary (pistons too, but a rotary more so.) since it is meant to burn oil by design.
Old Feb 13, 2003 | 07:58 AM
apexkw's Avatar
in slow, out fast!
we are talking about the dif and tranny and think you are talking about the actual engine oil.
Old Feb 13, 2003 | 08:13 AM
LAracer's Avatar
I have redline in mine, but alot of people claim neo is better.
Old Feb 13, 2003 | 08:39 AM
rotary-tt's Avatar
2 babies - no back seats
Not a hard job if you can get both drain plugs out. Mine had thread sealant and I had to use a 2' pipe to get the small square one out. I change the trans, diff, brake fluid, and coolant every 2 years or so. If I raced it I would change it much more often...
Old Feb 13, 2003 | 09:10 AM
DamonB's Avatar
Buy a gallon of NEO from www.bakerprecision.com
If you are careful one gallon is just enough to fill the tranny and the diff. I don't spill like Max does
Old Feb 13, 2003 | 09:20 AM
HeatTreated's Avatar
Hi Powr FD's
Make sure you get atleast 5 ft. of 3/8" rubber hose to fill the tranny case back up with fluid. 2.5 quarts is what the manual states and thats exactly what it held before it started spilling out.
my $.02
Old Feb 14, 2003 | 12:43 AM
maxcooper's Avatar
WWFSMD
The manual says 2.5 L = 2.6 US qts = 2.2 Imp qts. I hate to be a stickler, but it is 2.6 qts, not 2.5.
-Max
Old Feb 14, 2003 | 12:52 AM
skunks's Avatar
when ever i change tranny fluid, i never spill a drop (not a single drop so far, no kidding)
just use a pressurize hose system like me and you won't spill a drop either (cost me 10 bucks to make from homedepot!!!)
Official homedepot racer #777 here
BTW: diff fluid and tranny fluid are 2 different types of fluid just to let the newbies know
Old Feb 14, 2003 | 01:18 AM
DavidR's Avatar
I used MTL in my transmission. It made a world of difference. I also used Red Line in my diff but I forgot which one.
Old Feb 14, 2003 | 01:20 AM
EviLPeNeviL's Avatar
Can't live without boost.
I change mine every 5k miles or so...... (just like I change my motor oil ever 1k miles, regardless of how I drove the car, oil filter every 2k miles)
The more often all the fluids are the better it is for your car.......
The suction hand pump thing equip that I use can be bought from ACE hardware for like $5......
-Dan
Old Mar 26, 2013 | 03:35 AM
RE.Amemiya.FD3S's Avatar
RE Suikoayanajim
Hey guys,
I live in the Middle East - Asia, Weather Temp here in the Winter is 66F - 84F (19C - 29C) and in Summer it is very very HOT! Weather temp reaches 100F - 115F.
Is MTL 80W-90 Transmission Oil good for my 7? Our Oil products are: SHELL HELIX, BP, Castrol, Mobil1... etc
Need your help guys, Thanks a lot.
Old Mar 26, 2013 | 05:28 AM
Mrmatt3465's Avatar
Lousy Crew Chief
Top Answer: 1
Holy thread ressurrection.
To answer your question, I would order online something other than those. Redline is trash in this gearbox. Gives a very notchy feel to the tranny in all temps. Amsoil mtf is decent and I didn't have an issue with it, but neo synthetic was the best in my opinion. Neo synthetic has a better cold viscosity that helped my second gear notch first thing in the morning. The only issue I had with neo is that after driving it hard one weekend at tail of the dragon, it sheared down and I regained my notchy second. If you daily your seven or don't drive I extremely hard regularly, I would recommend the neo synthetic 75w-90.
Matt
Old Mar 26, 2013 | 12:57 PM
RE Suikoayanajim
Matt
Is MTL 80w90 GL-4 or GL-5 good for my 7?
I only drive on weekends and on special occasions.
Najim
Old Nov 21, 2013 | 11:01 PM
TonySeagle's Avatar
You got beef?
I have a question. I was somehow able to put in three quarts of gear oil (32oz bottles). I have read that it shouldn't be able to do this and that it would otherwise seep out the fill hole. Can somebody clarify? I'd rather deal with this while the tranny is out. The fill hole I am referring to is the larger of the two "square" protruding bolts on the driver's side. Thanks!
Old Nov 22, 2013 | 06:50 AM
Sgtblue's Avatar
Urban Combat Vet
^Was the car level?
The transmission itself should take ~ 2.5 quarts at the fill plug. But if you also changed and re-filled the shifter reservoir, which is separate, another .5 quart might be close for a total. ??
Old Nov 22, 2013 | 09:53 AM
TonySeagle's Avatar
You got beef?
Originally Posted by Sgtblue
^Was the car level?
Transmission was out of the car on a tranny jack. The tranny itself was level. I put three quarts in it without it overflowing. I read another member was somehow able to drain 1 gallon and filled it with 1 gallon. Not sure how accurate that is, but I am only 1 more quart away from that. The previous owner completely drained the tranny.
