Running REW twins on FC
Old Feb 11, 2003 | 12:04 PM
Suds7's Avatar
Is it worth attempting to fit 3rd gen twins on an fc? I don't have the money for a big single right now and twins would be nice, is it a mess when they are rigged up non seq?
Old Feb 11, 2003 | 12:19 PM
j9fd3s's Avatar
Community Builder
they wont clear the lower intake manifold, on an fc. its also the same amount of work as going single
mike
Old Feb 11, 2003 | 12:35 PM
600HP CLUB's Avatar
i think cosmo 13bre twins would fit because i was going to buy it from this guy who had the twins on his turbo2 and was selling it to me for 300 but i decided to go with a large single for my fc.
maybe one day twins
Old Feb 11, 2003 | 01:17 PM
Suds7's Avatar
what about a jspec s5 manifold?
Old Feb 11, 2003 | 06:22 PM
Node's Avatar
wouldnt have EGR and some other ****, not sure what else they don't have on them.
Old Feb 11, 2003 | 11:34 PM
Suds7's Avatar
Node: I have a jspec manifold
Just wanted to know if it would fit better with one vs with us spec.
Old Feb 13, 2003 | 09:31 PM
rx7tt95's Avatar
Photo Diety
I purchased a Cosmo motor to swap into my FD w/single setup...I have the Cosmo turbos for sale if you're interested...$250 plus shipping, complete. E-mail me at RX7tt95@aol.com if you're interested. I've heard this is a pretty good setup on the 2nd gens..I also have the Cosmo upper/lower manifold for sale. FYI, the primary turbo on the Cosmo is identical to the FD but the secondary is actually larger than the FD's.
Old Feb 15, 2003 | 06:34 PM
bkapold@aol.com's Avatar
My friend has a TII with Cosmo 2 rotor motor w/ TT's and it fits with ease...
Brad
Old Feb 16, 2003 | 05:39 PM
rx7tt95's Avatar
Photo Diety
Cool thanks for the info! I did find out that you cannot use the Cosmo upper/lower intake with the 13B (TII) block...which is a shame. I just returned from Rotorfest in Gainesville (Pistons vs. Rotors World Finals) where there was more than one pro-style drag car using this intake. One specifically, a 2nd gen, runs in the 7 second range. He said the Cosmo intake produces more torque than the FD. I'll post some pics after I get them developed. My digitals are at the shop being cleaned/calibrated and fixed :-( Had to resort to the old fashion cellulite stuff, film.
Michel
Old Feb 16, 2003 | 05:51 PM
600HP CLUB's Avatar
13-RE manifold equipt on 13BT
http://www.fullboost.com.au/cars/fea...rx7_chris.html
9 SEC Dragster.
-mike
Old Feb 16, 2003 | 06:04 PM
rx7tt95's Avatar
Photo Diety
Awesome! thanks Mike :-) Oh, the Cosmo intake I had for sale is sold but the Cosmo turbos and assembly are still available. FYI, the Cosmo LIM will not line up without the use of an adapter which pretty much kills the reason for running it in the first place (ruins what makes it efficient). I think Chris runs an FD block.
Old Feb 16, 2003 | 09:49 PM
rx7tt95's Avatar
Photo Diety
Clarification on the above, the Cosmo LIM doesn't line up on a 13BT block. Lines up just fine on an FD block.
Michel
Old Mar 1, 2003 | 06:15 PM
keeeah
Mich .. .. so you did get the "stuff" I sent you
... but... you're not supposed to smoke it all at once !
Old Mar 1, 2003 | 06:21 PM
rx7tt95's Avatar
Photo Diety
LOL, yeah I found out the hard way!
Everything is sold too, turbos, intake, etc...rebuilding the engine now. Full port job, polished everything. Lots of bling bling. Hopefully she'll provide lots of go go. If not, I'll just smoke some more of that "stuff" and It'll feel plenty fast! :-)
Old Mar 1, 2003 | 06:27 PM
keeeah
Old Mar 1, 2003 | 07:31 PM
rx7tt95's Avatar
Photo Diety
Damn it Richard....lay off that stuff...you're double posting now. :-)
Old Mar 2, 2003 | 02:44 PM
Astro's Avatar
So the cosmo 13b UIM can be bolted up to the13brew with very little or no modification?
Old Mar 2, 2003 | 03:39 PM
rx7tt95's Avatar
Photo Diety
The UIM and LIM will bolt up to the FD's block. Once it's on, there are two main issues. First, when you attach the FD's throttle body, what I believe to be an air bypass channel is left exposed. Related, when the throttle body is attached and one goes to attach a GReddy or stock elbow, you'll find the TB sits about 1" inboard of where it would normally be. The easiest way would be to create an aluminum or even phenolic spacer. The LIM will also need to be port matched to the REW's intake ports as the RE ports are much larger.
One racer simply told me to weld up that air channel. Not sure how it would affect idle, but he didn't seem to have a problem with it. Then again, it wasn't a street car but a 7 second drag car :-) I'm sure some piping would have enough fidget room to work with the 1" to the center elbow too but I haven't done this in person. Actually the oil filler neck may interfere. A spacer wouldn't be much of an issue though if you have a fab or machine shop near you.
streetlegal?
Mar 17, 2022 02:46 PM
bb6guy
Old School and Other Rotary
Oct 1, 2018 08:07 AM
bb6guy
Aug 12, 2015 03:29 PM
