Do FD's use top-feed or side-feed injectors?
Old Feb 11, 2003 | 12:28 AM
Anyone also care to explain the difference. Thank you.
Old Feb 11, 2003 | 12:29 AM
GoRacer's Avatar
Speed Mach Go Go Go
Side feed (fuel feed into the side of injector).
Old Feb 11, 2003 | 04:39 AM
roadsterdoc's Avatar
94 FD, 69 Datsun Roadster
The primaries (550cc) are top feed, while the secondaries (850cc) are side feed. Side feed injecotrs have fuel input from the side of the injector body (they fit into the fuel rail instead of the rail at the top). I do not know what other engines have this setup, all the other engines I know use top feed. I imagine it was a space issue when designing the engine.
Old Feb 11, 2003 | 02:26 PM
BicuspiD's Avatar
Infamous...Butcher...
I believe all four of the RX-7 injectors are side feed, as are many japanese OEM cars..
3SGTE
SR20DET
2JZGTE
to name a few. The side feed design allows the fuel to act as a cooling agent to the injector, immersing the entire unit fuel drops the operating temps. It also allows low-profile installations. However, Some impedances/flow rates are simply not available in the side feed design due to physical limitations.
Old Feb 11, 2003 | 03:35 PM
DamonB's Avatar
ALL the stock FD injectors are side feed. Aftermarket fuel rails typically use top feed though.
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
connerfd3s
Sep 19, 2015 05:58 PM
