high flow twins
Old Aug 15, 2001 | 10:45 PM
LT1-7's Avatar
John
high flow twins
does anyone know how todo this mod? Can I just port the housing and get bigger wheels? Has anyone ever done this? I want to keep my twins and run mid to low 11's. Anyone, please!!!
Old Aug 16, 2001 | 09:17 PM
Mr. Mahtab's Avatar
Re: high flow twins
I had Pettit do mine....whoa mama! Look out!
They sure work good now!
Old Aug 16, 2001 | 10:06 PM
the_glass_man's Avatar
Will u do me a kindness?
M2 Also has ball bearing high flow stock turbos.
Might be worth checking out.
Old Jan 9, 2003 | 11:36 AM
There is also the BNR Turbos, which ones did you end up going with?
Old Jan 9, 2003 | 02:12 PM
HeatTreated's Avatar
Hi Powr FD's
I might as well ask this here... but are our turbos non-ball bearing? Im assume so because the small trim size is sufficient enough to allow it to spool up quickly that the ball bearings arent needed.
Old Jan 9, 2003 | 04:17 PM
what happened to the lt1?
Old Jan 9, 2003 | 05:45 PM
SleepR1's Avatar
Get the '99 JDM Type RS/RZ twins. You'll be MUCH happier...
Old Jan 9, 2003 | 07:43 PM
Mazdabation's Avatar
Why is this??
I am interested in a upgade eventually also, and would like to stay twin.
Is it better to go 99 spec RZ, or upgrade the stock twins at BNR or some where like that??
What are the pro's and cons to the above mentioned??
Cheers
Shawn
Old Jan 9, 2003 | 08:55 PM
LT1-7's Avatar
John
haha, I asked this over a year ago
Old Jan 9, 2003 | 09:43 PM
BoostedRex's Avatar
NorCal 7's Co-founder
All kinds of pros going with BNR like more power, similar spool times, unmatched quality, great customer service, reliable build quality.
Cons - NONE!!
I don't know much about the Pettit or M2 upgraded twins, but both of those names are known for quality in the rotary community. Just my .02
Zach
Old Jan 10, 2003 | 02:29 AM
Marshall's Avatar
The only negative with these things is that they have been on 3 or 4 cars for less than 2 months and there isn't any real data on power, spool, or reliability yet. ...But Bryan's customer service and warranty still makes them a pretty safe bet.
Old Jan 10, 2003 | 08:46 AM
artguy's Avatar
WTB** Very Low Miles 94-95
there have been posts in regards to the stage two set being rather laggy down low on the bnr set.
I am very happy with my m2 turbos response and power gains. I am working hard to get a dyno sheet for you all. Id hope I have it by the end of the month.
good luck
j
Old Jan 10, 2003 | 09:49 AM
capt. bill1's Avatar
"I might as well ask this here... but are our turbos non-ball bearing?"
Yes they are non-ball bearing.
Old Jan 10, 2003 | 03:13 PM
So are you better off to keep the U.S spec turbos and have them upgaded?
Or go with new/used 99 spec twins?
Also if you want down the road, could you up grade the 99 spec to??
Cheers
Shawn
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
