carb mods for turbo 12a
Old Feb 8, 2003 | 09:33 AM
masterrigger's Avatar
what carb mods do i need to do to run on a blow-through setup? (using holley 600) will the stock fuel pump work (79 rx7) ? this motor is stock port
Old Feb 8, 2003 | 09:45 AM
RotorMotorDriver's Avatar
Seven Is Coming
Im sure you need to do something, but I dont know what.
No the fuel pump wont work...At all.
Do a SEARCH. Theres LOTS of people out there doing this.
~T.J.
PS - Welcome to the forum .
EDIT: Ok, maybe not lots of people, but lots of information .
Old Feb 8, 2003 | 11:13 AM
Sammymatik's Avatar
Re: carb mods for turbo 12a
From what I've read with a holley there is not too much modification necessary. You'll have to change the float to a solid type so the pressure doesn't crush it!
Here is a great link with a ton of turbo/super charger carb info!
Enjoy!
http://www.vs57.com/carb.htm
Th0m4s
Feb 26, 2019 02:04 AM
alphawolff
Nov 17, 2015 05:57 PM
rx7brandon
Aug 16, 2015 10:55 AM
