Brake - Master cylinder problem
Old Aug 15, 2001 | 08:18 PM
turbovr6's Avatar
The air noise you hear is from the power assist unit not the master cylinder. Some hissing when you hit the brake is normal, when the power assist goes bad, the pedal is rock hard, not soft. As far as your pedal problem, it sounds like you still have some air trapped in the system. Did you bleed in the proper sequence??
josef 91 vert
23
Sep 3, 2015 11:20 AM
rx7shirley
Sep 2, 2015 02:11 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
