Buying tips!!
Old Feb 7, 2003 | 12:31 PM
d4rren's Avatar
Newbie
Buying tips!!
HI all
im looking to buy a 1993 RX7 twin turbo but i have no idea what to look for???
I have heard that the engines are a week point but what on the engine??
Any buying tips will be very greatful.
cheers d4rren
Old Feb 7, 2003 | 12:47 PM
apneablue's Avatar
Wow, you have lots of research to do...
first you wanna take a boost gauge with you and verify that the boost is what it's supposed to be (10-8-10) search if you don't know.
If the engine is nearing the 80k mark you will probably need a rebuild soon...something to look for is excessive smoking on startup...some is normal as most of us experience that for the first couple of minutes...but when you car has a hard time idling on startup and smokes like hell then it usually means that the coolant o-rings are going...(rebuild time...there is a temporary fix for that but probably would be best to factor in the cost of a rebuild if you are going to purchase it)
Then you should have someone do a compression test on the motor.....you have two rotors with three faces each...you will get back six numbers from your test...numbers are usually from 7 - 9...9 being excellent and 7 being ****. the results will look something like this 8.2, 8.5, 8.1 - 8.3, 8.1, 8.0......each number represents one of three faces of a rotor and the compression it kicks back...
So that plus oil leaks and coolant leaks...
Make sure you get to start the car when it's cold because once it been running for a while and you start it warm you usually don't see white smoke from it...
Anyone else want to contribute or criticize my post?
Old Feb 7, 2003 | 12:56 PM
Mld>7's Avatar
I Post Mad Quick Yo!
Also be sure to take it for a nice test drive.. Look for a bref rev stutter at around 3-3.5k rpm.. If you consistantly get it just walk away from the car. 90% of the time its not fixable.
Old Feb 7, 2003 | 02:27 PM
Mahjik's Avatar
Mr. Links
Arrow
Check this post:
https://www.rx7club.com/forum/showth...hreadid=147498
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
jdayau
Nov 29, 2019 12:11 AM
SakeBomb Garage
Oct 9, 2015 10:05 PM
