? for guy's who got they 80 engine to work with mazda oil pressue sending unit?
Old Feb 5, 2003 | 09:16 AM
Rx7aholic's Avatar
Hey I just finished my custom made adapter to accept the mazda oil sending unit, as most of u know that the 80 does not comes with a oil gauge and a sending unit. Anyway I made my 80 to accept the 82 gauge cluster that comes with oil gauge and custom made an adapter to accpet the sending unit.This is what I did drill the rear oil line bolt and tap it. I have thread good for the sending unit but I use a white teflon tape on it so it won't leak? Now for my ?,what other seal can I use beside the teflon tape? I have test it and rev the engine and I don't see any sign's of oil leaking but with the rotary heat u never know what can happen to the teflon tape? thanks, khris
Old Feb 5, 2003 | 10:22 AM
Sammymatik's Avatar
Re: ? for guy's who got they 80 engine to work with mazda oil pressue sending unit?
Sounds like an interesting idea. I have an 80' engine as well and I'm going ot need to do something abut the oil guages. What you did is a good way to save $45.
Old Feb 5, 2003 | 05:49 PM
Siraniko's Avatar
RX for fun
i use liquid teflon and havent seen any problem.
Old Feb 6, 2003 | 02:03 PM
Wankelguy's Avatar
My FSP Fiesta eats Jettas
Are you saying that you drilled and tapped the banjo bolt that attaches the oil cooler line? That shouldn't get too hot to cause a problem with teflon tape.
Old Feb 6, 2003 | 05:06 PM
RotorMotorDriver's Avatar
Seven Is Coming
I saw one in the junk yard like that. He had a liquid sealant on there. White stuff, kinda like what you would put on pipe threads. Probably the same stuff.
~T.J.
Old Feb 6, 2003 | 11:15 PM
Siraniko's Avatar
RX for fun
also, what you can do is add a "T" on the banjo bolt fitting to accommodate for a stock oil pressure and after market gauges.
Old Feb 7, 2003 | 12:10 AM
Seven Is Coming
Or buy an oil distribution block from Steve at www.rotaryautosports.com . They look great and work great too .
~T.J.
Clacor
Aug 14, 2015 09:17 AM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
