a dumb newbie question
In the build
ive got a s4 turbo and im gonna do very basic level racing. dont need a roll cage etc. amm i was jus wondering wat settings u would recommend i set my Koni adj (yellow and jus the stiffness adjustable) shockies to. i dont care about the harshness i jus want the best handling possible. also wat tyre should i get ive got 17x8 mags but i want like a road legal semi-slick so that i get good grip without tearin up the trye to much good idea or not or should i jus get a road tyre also wat widths are best???
kumho victoracer v700 is great...
bfg G-force, Nitto 555 ZR, Yoko A032 all could be pretty good performing tires...
225 is probably a good size... you are limited to the front spacing. on the S4, you can't fit very big tires unless you go crazy with the wheel spacers.
Adaptronic S5 Turbo PNP Unit questions
_Tones_
May 25, 2021 05:37 AM
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
