premix degrading fuel, how bad??
Old Feb 2, 2003 | 01:28 PM
93redFD's Avatar
does anybody know how bad 2 stroke oil degrades the fuel??? 4oz in 20.1 gal tank??? I very curius becuase I want to run around 18 psi on pump gas, but im worried about the octane being degraded becuase of the 2 stroke oil. Does anybody know how many point it may drop??
Old Feb 2, 2003 | 04:15 PM
rxseven's Avatar
Special Dark
4oz in 20 gal? Not even 1 point on the octane rating.
Old Feb 2, 2003 | 10:08 PM
Suds7's Avatar
What about 12 oz in a 16 gallon tank?
Old Feb 3, 2003 | 12:26 PM
93redFD's Avatar
dude,12 ozs is way to much for 16 gal tank. Chris at rotary performance only recomended 4 oz per full tank, (20.1 gal). thanks..
Old Feb 3, 2003 | 02:18 PM
riffraff's Avatar
smog nazi destroyer
i was suggested to run one oz. for every gallon of fuel. thus 14 oz for a 14 gallon tank... (this is for a first gen though.. could it be different)....
Old Feb 3, 2003 | 06:22 PM
rxseven's Avatar
Special Dark
1oz per gallon if using premix exclusively. If you are using it with the omp, 1/3 oz. per gallon is more than adequate and will not cause excessive smoking.
Even with 1oz. per gallon, the octane rating is hardly affected.
Old Feb 4, 2003 | 01:52 AM
chohakai's Avatar
if I recall correctly, 100:1 ratio results in a .2 octane drop (or maybe it's for 200:1). Crap..... Don't remember clearly now.
Old Feb 4, 2003 | 10:39 AM
Suds7's Avatar
I run exclusively premix
Old Feb 4, 2003 | 03:32 PM
SPOautos's Avatar
Hey, where did my $$$ go?
I run straight premix, I dont even have a omp. I've been running 8oz for a full tank of gas.
Is this enough??? Should I be running more?
100:1 is 23oz for a full 18 gallon tank of gas!!!!! That seems like way too much.
Lets look at it like this. When I was on straight omp alone I would loose about a qt of oil in 1500 miles. Assuming all that was being lost due to the omp that means that I used one qt (32oz) of oil for about 100 gallons of gas, which would break down to the omp injecting about 5oz per tank of gas.
So if the omp was doing about 5 oz of 20/50 engine oil how does that compare lubercation wise to me doing 8oz of synthetic premix or MMO???
Surely somone knows for sure!!!!
STEPHEN
Old Feb 4, 2003 | 04:49 PM
Hmm, I talked to Mazdatrix and they told me 1-2oz per gallon. So I went with 1.5oz with no omp and my car never smoked. Just some input. My engine didn't last long enough to pull the plugs and check. It seemed ok to me though.
Old Feb 4, 2003 | 07:31 PM
rxseven's Avatar
Special Dark
Stock omp ratio at full throttle is 150:1 if I remember correctly. So 1/2oz./gallon is not adequate if you constantly flogged the bitch and redline it. 1oz./gallon is what I would suggest.
Old Feb 6, 2003 | 08:19 PM
Amur_'s Avatar
Refined Valley Dude
RETed's site.
http://fc3s-pro.com/TECH/FAQ/premix.htm
Old Feb 7, 2003 | 12:42 AM
SPOautos's Avatar
Originally posted by Amur_
RETed's site.
BTW - Where has RETed been??? I havent seen him around in forever!!!!
STEPHEN
Queppa
Nov 18, 2024 03:47 AM
Jun 26, 2016 10:21 AM
alphawolff
Nov 17, 2015 05:57 PM
armans
Aug 15, 2015 09:08 PM
