Microtech N/A Fuel Maps...
Old Feb 2, 2003 | 02:10 AM
Liquid Anarchy's Avatar
We come with the Hardcore
N/A Fuel Maps...
Seeing as the LT8 unit is australian, and there are no N/A's in aussieland; are there any N/A fuel maps?
Old Feb 2, 2003 | 04:22 AM
10sec rx7's Avatar
There are heaps of N/A's in aus dude, just not as many as turbos. there are N/A maps avaliable, but as with every map they will require a little fine tunning to different motors.
Dale
Old Feb 2, 2003 | 04:40 AM
Anthony Rodrigues's Avatar
NA Maps
I think you will find that if you post your set up one ofus will be able to give you a good base map to start with. We need to know injector type size/ porting etc..
Regards-Anthony
Old Feb 2, 2003 | 01:05 PM
by the time that I get the thing...
Big Stage II Streetport, Emissions Removed, A/C & P/S removed, Ported/Polished/Bead Blasted/nipples removed intake, PR Sleeves, CAI, TB Mod, Electronically Actuated 5/6th and VDI (I'll need a pair of RPM switches), Header~>Presilencer~>Single Exhaust...
Running w/ 460cc injectors, getting a TII Fuel Pump, could get 550cc's if needed.
Old Feb 3, 2003 | 05:23 AM
rxeng's Avatar
Yeah that will be no problem.
We'll be able to give you something that will be pretty damn close from what you've described there.
Jon
Old Feb 3, 2003 | 11:07 PM
Piranha's Avatar
what 7
Well, I'm definately impressed with the support for Microtech here....
TwentyDW
Sep 2, 2015 06:42 PM
