will an84 brake master fit and 80?
Old Jan 30, 2003 | 09:58 PM
79+80_rx-7's Avatar
Will it?
Mine is shot in the 80, and am scared to drive without brakes, they work, but only if you pump them like three times, and then only they barly work....
I have an 84 with healthy brakes.. and it just sits without a motor right now, so......
I think the thread pitch is different, but cant i reflare it? Or, is there adaptors for cheap?
Thanks! Andrew...
Old Jan 31, 2003 | 06:38 AM
inittab's Avatar
I read your email
Re: will an84 brake master fit and 80?
I fail the see the problem
The Mazda part numbers are definitely different. The 79's are different than the 80's and the 80's are different than the 81-85. I wouldn't screw around with mix/matching the brakes that way IMO. Talk about scared.... ya might end up with brown trousers when you need your brakes the most....
Just me 2 cents.
Old Jan 31, 2003 | 09:34 AM
79+80_rx-7's Avatar
okay, your right...... i dunno why either.... But does any one know? I guess i could reflare it... i cant afford a new one, or a kit, so im using what i can....
I dont drive far, just doing test runs, till everything is legalized, and i have quite a bit to do before then! Well, i would like brakes ASAP.....
And can the 84 slave cylinder work on mine, if i swap the forks also? Thanx!
And I am curious to why not many people reply?!?
Old Jan 31, 2003 | 12:44 PM
specRX7_22's Avatar
my dad and i used an 85 booster on an 83? so i dunno
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
Frisky Arab
13
Aug 18, 2015 05:30 PM
