Relationship between high boost and engine life.
Old Jan 29, 2003 | 11:43 AM
eViLRotor's Avatar
Brother of the Rotary
All you guys running high boost, 15-20+ psi on a regular basis (which is probably everyone here ):
Do you have any idication of the expected life-span of your engines (assuming its well tuned, of course)?
IAN had a discussion with a well respected rotary guy here in Canada, and he said they usually last a couple of years. Ouch
I know there are mainly 13B-REW guys here, but I'm sure it the same standards apply to the 13B (I'm running 14 psi daily).
Old Jan 29, 2003 | 01:42 PM
Bridgeported's Avatar
I'd estimate on a streetported 13B running 15-20 psi daily... the engine will last anywhere from 0 - 5 years. (range dependant on quality of tuning).
If I'm not mistaken RICE RACING has been running a pretty high boosted 13B for a number of years now, I could be wrong though?
Old Jan 29, 2003 | 02:21 PM
es's Avatar
es
Re: Relationship between high boost and engine life.
The B-REW has higher compression rotors which would tend to detonate easier, BUT the later model FD has increased side clearance rotors which could reduce the torsional stress under high boost...
Old Jan 29, 2003 | 02:31 PM
nocab72's Avatar
03 Cobra Killer
I am not normal. Most locals can probably confirm that for you if you doubt me.
I expect to be on the 24 mo engine replacement plan. I don't plan to blow any of my motors, but will replace them as "used" after their second season (estimated 20k miles). Since I am buying Pineapple motors with 5yr/60k warranty, I'll have to see what I can work out with Rob to see if transfering the warranty to a new owner is an option. If so, I'll have a nice broken-in Pineapple motor with the balance of the warranty to sell in 18months (or less).
K
Old Jan 29, 2003 | 02:43 PM
eViLRotor's Avatar
K
Yeah, that's not the plan that I'm on...LMAO
Queppa
Nov 18, 2024 03:47 AM
Wolf_
Aug 11, 2015 04:23 PM
