Headlights wont stay in low beam - will go to high beams
Old Aug 14, 2001 | 05:56 AM
The Ace's Avatar
Greek Power
Unhappy Headlights wont stay in low beam - will go to high beams
I know that the solution might be obvious, but just to make sure: in my gen2 Turbo II the lights control is semi-broken, and I am having difficulty changing between low and high beam. The problem is that if I am at low beam, and I hit a bump, a hole or something that'll make the car rock, the lights will go into high beam (they will go back and forth between low and high like some contact is fried). Is it just the control which needs replacing (the one on the left of the steering wheel), or some wiring, plug, fuse or contact needs also fixing ?
Old Aug 16, 2001 | 04:12 AM
The Ace's Avatar
Greek Power
Problem fixed: one of the relays that are on the bumper what almost off its hook. Took it out, took a look, reinserted it, works just fine...
gxl90rx7
Haltech Forum
Sep 14, 2015 03:09 PM
