YAY! Got myself a carb, so only a few more things before my car will be good to go.
Old Jan 26, 2003 | 03:55 PM
79+80_rx-7's Avatar
I found a good carb, when me and Eric(rx7gslse) went to the junkyard. It says it was rebuild 2-18-00 by CSC in Irving. It looks REAL good.... Looks like it has been sitting for about 4 months, but i think it should work well. I will run some carb cleaner in the tank, when I can get it on.
I still need to get an intake gasket, and o-rings, before i can put it back on. It is off an 85. but that shouldnt matter much.
So, here is what I need, for it to be a good daily driver.
1.) Tires- will go to discount tires to replce these rotten ones.
2.) Black carpet- Will go somewhere cheap, and it shouldnt cost more than $20.
3.) Paint- I need some to paint the interior panels(AGAIN) some black Plastikote(rubber stuff) for all the black pieces, and then some high tempature engine paint(silver-ish) for the rest.
4.) JB-weld- for the intake manifold.
5.) Intake manifold gasket, and o-rings.
6.) Rear shocks(Found one at the yard for cheap)
7.) Gauge cluster(Found one at the yard for cheap)
Future Mods.
1.) Direct fire ignition.
2.) Complete my exhaust system.
3.) Electric fan (have one, need an installation kit)
4.) Port my intake even bigger
5.) Mechanical Secondaries
So, finally at last, I am one MAJOR step closer. Now with the money that should be sent to me shortly (like $35) I will get my intake gasket, and o-rings, and the paint/jb weld I need....
Well, just wanted to post that i got a carb,and the status of my car!!! SOOOOOO Close....
Laters, Andrew
Old Jan 26, 2003 | 04:06 PM
85RX7GS's Avatar
Old Jan 26, 2003 | 10:16 PM
79+80_rx-7's Avatar
i still will need a radio will see after i get the exhaust done,hehe
peace
Old Jan 27, 2003 | 12:25 AM
RotorMotorDriver's Avatar
Seven Is Coming
Hey man, Im happy for you. I remember when I was building my car in my Dads garage. It took me what seemed like forever (about a year in reality), and Im still not done . This is a never ending process, haha. Let me know if I can help ya out or anything .
~T.J.
Old Jan 27, 2003 | 08:43 AM
rx7gslse's Avatar
EX Pres of DFW Drunks
and it's such a pretty carb isn't it?
Old Jan 28, 2003 | 09:45 PM
79+80_rx-7's Avatar
yes,its pretty, specially when mounted!!!
when it does run, get my 86 alternator on there... and my fans....... then with the spare ignitors i have, direct fire!...
peace...
Old Jan 29, 2003 | 07:44 AM
85RX7GS's Avatar
Sounds like a plan! Are you going to use the stock coils or some aftermarket brand when you set it up for direct fire?
Old Jan 30, 2003 | 08:17 AM
79+80_rx-7's Avatar
MY CAR RUNS!!!
Im so happy..... SOOO HAPPY
Its fast too!!!
I needa clutch slave, and abrake master..
I have clutch, if i pull it from the floor with my foot, so the fluid would be vacumed back into the clutch master...
And my brakes are shot.. I NEED To get Mario over here, to tell me if its the master or not.....
And I want him to test drive it
I NEEED new tires up front also.... cause when cornering the car SLIDES BAAAD!!!! I tried to take a decent 90* corner, and almost went into the ditch...
Well, anyone that can help out, i will appriciate it
Thanx, Laterz, Andrew
alphawolff
Nov 17, 2015 05:57 PM
ashleymiche
Aug 14, 2015 12:59 PM
meat_whistle
Aug 12, 2015 08:41 PM
