400 rwh from stock engine/turbos !!!
Old Jan 25, 2003 | 05:31 PM
Boostn7's Avatar
For those that said it could not be done .......
Just got off the dyno and here are the results...
402 rwh and 356rwt.....
4x850cc injectors maxed out !! mid-high90% !!!
map sensor....maxed out...1.13-1.14kg/cm2 or 17.5psi
air/fuel ratio.....mid-high 10's 'til 6krpm and 11.0 after that..
Later
Old Jan 25, 2003 | 06:38 PM
How much boost did u pull out of those stock twins???
Old Jan 25, 2003 | 07:01 PM
Boostn7's Avatar
17.5psi maxed the stock map sensor....
Old Jan 25, 2003 | 07:06 PM
Boostn7's Avatar
Dyno sheets of course........
Old Jan 25, 2003 | 07:19 PM
Boostn7's Avatar
and another....
https://www.rx7club.com/forum/attach...postid=1437560
Old Jan 25, 2003 | 07:35 PM
vosko's Avatar
Just Call Me Terminator!
congratulations. i knew you could do it! i can't wait to get some more video of you running and hopefully breaking the 10.99 barrier
Old Jan 25, 2003 | 07:43 PM
Bridgeported's Avatar
Wow! Very impressive.
Your engine is completely stock inside?
Old Jan 25, 2003 | 09:41 PM
Evil Aviator's Avatar
Rotorhead
Which EMS are you using?
Old Jan 25, 2003 | 10:30 PM
vosko's Avatar
powerFC and yes i have seen the car engine is stock! i saw it before when it only 12's..... LOL
Old Jan 25, 2003 | 10:34 PM
Scalliwag's Avatar
WingmaN
That really rocks!
Old Jan 25, 2003 | 10:51 PM
Rotorhead
OK, I was just wondering, because Checkpoint recently made 400hp on stock twins with a Wolf EMS. Pretty impressive for a little 1.3L engine.
Old Jan 26, 2003 | 07:35 PM
very very nice numbers
This is what we need to see more of !
Old Jan 27, 2003 | 03:55 PM
forcefed1's Avatar
MAN awsome. I sure am glad all you guys are spending these cold winter months tuning. care to share some tuning strategy with the rest of us? are you running water injection by chance? what fuel were you using?
real real good job man!
so how much dyno time do you have in trying to get there?
Old Jan 27, 2003 | 03:57 PM
ZeroBanger's Avatar
Re: 400 rwh from stock engine/turbos !!!
Later
What are your mods? You have identical a/f as me, I dynoed at 315.8 @ 12 psi.
Thanks
Old Jan 29, 2003 | 05:57 PM
fstrnyou's Avatar
I have an 88 TII. I was just wondering what numbers I could get with stock turbo, and maybe a street port. I guess 14psi would be a reasonable amount. Full exhaust and TID of course. Thanks
Craig
88 TII 80k miles no mods yet
Old Feb 3, 2003 | 10:25 PM
now all you need is some turbos that can flow
Old Feb 10, 2003 | 09:11 PM
thedguy's Avatar
What mods (i.e. exhaust...) are you running besides the EMS?
Old Feb 11, 2003 | 02:01 AM
darkside7's Avatar
holy ****!!!!!!!!!!!!!
Old Feb 11, 2003 | 11:44 AM
Bigreddawg's Avatar
Do you by any chance have the SAE corrected numbers?
Old Feb 11, 2003 | 12:36 PM
killa7lb's Avatar
have you taken it to the track yet....the number posted was before you made that hp? i have a friend who made like little over 350hp with stock twins...he ran 11.2, his internals was not stock....so i guess you're a mile ahead of the pack if you should port your motor and bigger turbo...correct.
Old Feb 11, 2003 | 11:24 PM
Boostn7's Avatar
the 11.56/11.59 @ 122mph were made with 1.08kg/cm2 on PowerFC *or* 16.5psi on boost gauge.
The car is now tuned to 17.5-18psi on pump gas and I'm just waiting for nice weather to attempt few passes on MT ET streets before getting kicked out from the track(no cage)
Nothing impossible....few been there before.
Old Feb 12, 2003 | 12:53 AM
GoRacer's Avatar
Speed Mach Go Go Go
Looks like you're running parallel. What are the other ingredients of your secret sauce?
Old Feb 12, 2003 | 08:26 PM
Tim Benton's Avatar
FD title holder since 94
no doubt the car made that actual HP, but what was the corrected HP. more or less interested since with the cold dense air in winter, your car will make more HP (actual) but be less in summer, the corrected values would help everyone see what it would make at dynojet known parameters (60 F, humidity, altitude, etc).
Tim
Old Feb 13, 2003 | 12:32 AM
Boostn7's Avatar
Yes Tim...those are actual hp numbers...
Did not touch computer settings on dynojet and ran it as it was setup.
The dyno was indoors with heat on......so I did not get the full advantage of the winter cold dense air.
FYI: intake temps varied from 35-40 Celcius.
But if you wanna see 400+rwh corrected numbers I will deliver them as well
Old Feb 13, 2003 | 08:37 PM
T88NosRx7's Avatar
That is awesome, congrats.
