GSL-SE Fuel filter, specialty item?
Old Jan 24, 2003 | 11:09 PM
ioTus's Avatar
'84 5-letter
So i got a generic universal clear view fuel filter, and went to replace the stock one.
Well the stock one is about 4 times larger than my small one, and it also has special angled connections to the fuel line.
Do i need a specialty part for the filter?
Old Jan 25, 2003 | 12:21 AM
mcgarret's Avatar
You bought the wrong filter. The SE filter is a metal cannister with banjo fittings at each end. The clear plastic filter will not be able to handle the higher fuel pressure from the EFI. The carb's use approx 6psi, 13B EFI is 40 psi or so.
Old Jan 25, 2003 | 01:47 AM
i think the little glass filter will work fine... The thickness of the glass on those little filters should break from 40 psi running through it.. Just my $.02...
Old Jan 25, 2003 | 01:57 AM
RotorMotorDriver's Avatar
Seven Is Coming
Just get the right filter dude .
~T.J.
Old Jan 25, 2003 | 10:13 PM
smnc's Avatar
EliteHardcoreCannuckSquad
Sounds like you got the right filter for the non GSL-SE models.
It not so much the plastic housing that won't hold up, but the non-SE's pump a much lower fuel volume. I doubt the filter element would be able to keep pace...
Old Jan 26, 2003 | 09:20 AM
Gregs's Avatar
word... get the oem spec filter
later
-greg
Old Jan 26, 2003 | 09:22 AM
lotsacars's Avatar
The correct filter:
Coming soon to a GSL-SE near me!
Queppa
Nov 18, 2024 03:47 AM
Rotospectre
Mar 28, 2018 03:33 PM
The1Sun
Mar 18, 2018 11:08 PM
alphawolff
Nov 17, 2015 05:57 PM
LunchboxSA22
37
Oct 26, 2015 10:53 AM
