intercooler piping size
Old Jan 24, 2003 | 03:54 PM
82streetracer's Avatar
8/1 Building/Drive Ratio
I just put a bid on a huge intercooler on ebay.
It has 3 in inlet and outlet.
I had originally planned on running 2.5 in pipe for the whole system. But is there any reason not to run 3in for hte whole system.
Old Jan 24, 2003 | 04:08 PM
Bridgeported's Avatar
Are you going to be running a large turbocharger with decent boost levels? If so, then the 3" will work great.
If you are running a mid-sized turbocharger and lower boost, then you would probably be better off with the 2.5" or 2.75" piping.
Old Jan 24, 2003 | 04:18 PM
Directfreak's Avatar
I am a Jeeper Now.
As long as at no point in the piping you go smaller than the Turbo Outlet, - you're fine.
2.75 piping is hard to get (read $$$). You can get different sized transitions, that go from 2.5 to 2.75, 2.5 to 3.00, etc..
Old Jan 24, 2003 | 05:08 PM
im going with the bnr stage 4, 60-1 compressor. 15 psi on 93 and 20 psi on 100
Im thinking 3in with that.
Old Jan 27, 2003 | 03:44 PM
Manolis_D's Avatar
Sounds to be too big. I'm running 2.5" with a full 60-1 turbo, and many people seem to do the same. I think 3" is going overboard here -- you'll end up with more difficult pipe routing as well as higher cost and more lag most likely.
-Manolis
Old Jan 27, 2003 | 08:51 PM
well I lost the bid on the intercooler anyways.
Anyone got a large style npr intercooler they want to sell. That would be perfect. I want to go overkill on this part.
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
yetter227
20
Sep 5, 2015 11:57 PM
