Upgrade Fuel Rail for T78 Single Turbo
Old Jan 24, 2003 | 12:09 PM
Northwest FD3S's Avatar
Rich Hoe
Does anyone know i f i should be upgrading my stock fuel rail? If so where can i go to get an upgraded fuel rail? Also what size injectors should i be using, I have a apexi power fc, and holley fuel pump. I will be running 12-15psi for daily driving and 16-20psi for the strip.
Old Jan 24, 2003 | 12:41 PM
mjw's Avatar
mjw
I would keep the stock primary rail, and upgrade the secondary rail to hold some 1600cc injectors. You can get them at the RX-7 store or K2RD.com
Matt
Old Jan 24, 2003 | 07:39 PM
Rich Hoe
Fuel Rail
Is there a place where i can get the fuel rail?
Old Jan 24, 2003 | 07:52 PM
allrotor93's Avatar
Matt
he said it
Old Jan 25, 2003 | 01:59 AM
Rich Hoe
He mentioned where to get the 1600CC injectors and not the fuel rail. I have checked these sites and there is no fuel rail on either. Please advise
Old Jan 26, 2003 | 03:34 PM
black99's Avatar
Lurking..................
Re: ????
You can get them from a number of places. A couple of people on the forum might be able to get them for you like crispeed has just designed a primary and secondary fuel rail set, and some others make them as well I think.
http://www.k2rd.com/catalog.html has their new page under construction but I think their secondary rail is about $200.00 normally. Not sure if that comes with -AN fittings or not.
RX7store.net sells a combo secondary fuel rail and 1600cc injectors for $410.00 http://66.216.67.51/product.asp?0=211&1=333&3=577
Old Jan 26, 2003 | 03:45 PM
tk5dan's Avatar
Re: ????
you take special ed classes right???
Old Jan 26, 2003 | 04:11 PM
sub-zero's Avatar
I sent You a PM for rails and injectors.
astrum
24
Nov 15, 2017 08:44 AM
