Alignment with different wheel diameter??
Old Jan 24, 2003 | 04:49 AM
Pumped's Avatar
ok I need to get a wheel alignment ,
does it matter what size tyre diameter it is ??
reason is that I powdercoated my stockers and I don't want the alignment tools to scratch my wheels (happened before with my previous car ) , so I was thinking of using another set of junker wheels so I dont have to worry about them getting scuffed up ,
but the problem is, the tyre diameter is about a half an inch taller than what I usually run...
so does it make a difference??
Old Jan 24, 2003 | 11:07 AM
jr426's Avatar
No, it will not make a difference. Make sure that the tires you are going to align it with are worn equally. Ex. don't have a new tire on rt ft and a worn out tire on lf ft as that will affect the alignment. Jeff
