How low can I go?
Old Jan 22, 2003 | 03:49 PM
CTX's Avatar
CTX
How low can I go?
hi, I bought another set of 18x8 rims with 215/35 tires. The key question is How Low Can I Lower An 89 GXL with 18x8's with 215/35's on it? I finally have the money to swing a set of coilovers... I looked at shox.com and seen the ground control coilover kit, 4 for $399 with 0-2" adjustable. Is this a good kit/deal? If any knows of any other good kits that they would recommend for my situation, advice would be appreciated =)
-Thanks
Old Jan 22, 2003 | 05:42 PM
SleepR1's Avatar
From the tire size, I assume that's an FC Rx7?
Old Jan 22, 2003 | 06:52 PM
CTX's Avatar
CTX
yes..thought everyone would know that =) 'gxl' and all
Old Jan 22, 2003 | 07:01 PM
maxcooper's Avatar
WWFSMD
That is the beauty of coil-overs. You can get them, start with a small drop, and then work your way down if you want to. If you run into trouble (rubbing), raise it back up a little and stop.
-Max
Old Jan 22, 2003 | 07:06 PM
CTX's Avatar
CTX
That is true, but i could possibly save a hundred bux or so by not buying the set with the most drop. Lets just say the car will rub after 1" drop. Whats the point of buying a set that drops 2" and costs more and will never be lowered any more than 1"? I might be making sense, i might not ;P
Old Jan 22, 2003 | 07:51 PM
maxcooper's Avatar
WWFSMD
I doubt you will get over 2" of drop, but it is somewhat possible that you'll get over 1". A lot of the adjustment range depends on what spring rates you get, and I don't think anyone makes any coil-overs that only adjust 1". The GC setup from shox.com (or ARD T2 here in the forum) sounds like a good bet. GC doesn't include shocks or struts, so you'll have to use what you've got or get new ones, which may affect the total price.
-Max
Old Jan 22, 2003 | 08:13 PM
CTX's Avatar
CTX
well, i dont know much, hell, i dont know anything about shocks or struts =) but the GC setup that i refered to will work with my existing setup? any info is needed
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
Logan Reinisch
44
Sep 17, 2018 12:20 PM
Jmpabon93
Sep 30, 2015 04:57 PM
