So close yet so very very far
Old Aug 13, 2001 | 04:37 AM
Agent_D's Avatar
rawr
all i can say is check to make sure everything is tight, intake bolts, no intake leaks, all vacuum lines are on right. i hear ya on the 11-12mpg thing, my manual gets around 24 in town and 29 on the highway, the auto only gets like 11-12 in town, maybe 20 if im really lucky on the highway, what is it with the auto's??
Old Aug 13, 2001 | 08:15 AM
Samps's Avatar
check the battery and the alternator, or better yet take it to pep-boys or advanced auto or wherever and have them check it with thier goofy machine. I had a shorted out battery that did that same thing to mine. If your battery goes dead more than maybe five or ten times the plates inside the battery will warp and if they touch each other they will short. The car will still run, just not good. Your situation is exactly what mine was and it was just a bad battery. So check it out and maybe you'll get lucky and fix it for 50 bucks. If not, good luck.
Old Aug 13, 2001 | 08:04 PM
HAILERS's Avatar
HAILERS
Warm the engine up and then do a compression check. What your checking for is to see if the front rotor and the back rotor are withing five or so psi of each other. If the variance is more than say 15 psi, that is your problem. Also, have you set your idle with the initial set jumper in place prior to setting the idle. Makes all the difference in the world if you did not. That last piece of advice is copied from Irv, Keiths dad.
Old Aug 20, 2001 | 02:45 AM
Mykl's Avatar
Pull the throttle body and make sure all the linkages are adjusted.
Also, make sure the thermovalve system is working properly. If that's fucked up no amount of TPS adjustment is going to help because you'll never be able to set it where it needs to be.
I fixed the fucked up thermovalve problem on my car by unhooking the spring on the fast idle roller linkage and wired it back with twist ties to keep it out of the way. Then I adjusted everything and it's idling fine now. Not perfect, but it no longer surges like it did because I was able to get a decent TPS adjustment in.
izzolaw
1st Gen General Discussion
Sep 27, 2015 08:33 PM
