Greddy, Good?
Old Jan 20, 2003 | 08:22 PM
Greddy, Good?
Watz up people, i have been hearing alot about these greddy turbos, are they any good? also, do they come in any twin kits?
Old Jan 21, 2003 | 01:59 AM
Bridgeported's Avatar
Yes, they are amazingly great.
I don't think Greddy sells twin kits.
The T78 is greddys most popular turbocharger for RX-7s. Power potential is good... 400-500 rwhp @ 12-20 psi
Old Jan 21, 2003 | 10:51 PM
Bucrx7's Avatar
Greddy makes a nice complete kit and they don't make twin kits. This is off topic but your name is almost the same as mine!!
Old Jan 22, 2003 | 04:55 PM
Are there any other mods needed right away in order to run that t78 turbo? Also, around wat 1/4 mile times do you think that will give me?
Old Jan 22, 2003 | 05:57 PM
Yes, it's not as easy as just slapping on the turbocharger.
Here is a rundown of the main things which need done:
- exhaust manifold
- ECU (preferably EMS)
- front mount intercooler and piping
- BOV and wastegate
- fuel injectors, pump, rails, lines
- ignition system
- full 3" - 3.5" exhaust system
- intake filter & piping
- clutch kit
- radiator
- oil cooler
It is also prefered to have your engine rebuilt and streetported before you put the turbocharger on. Your gains will be FAR more impresive with the streetport.
With a T78 on a streetported 13B, your power is dependent on the boost you run, but expect anywhere from 400-500 rwhp @ 15-25 psi.
It can put a stock weighing FD into the 11s or the 10s if you run higher boost.
streetlegal?
Mar 17, 2022 02:46 PM
cristoDathird
28
May 30, 2019 08:47 PM
