UUHH OOHHHH... This aint good!
Old Jan 20, 2003 | 03:31 PM
ejmack1's Avatar
Lawn Ornament
Drove my car for the first time in about a week this morning, right after installing a catback exhast(i do have an aftermarket ECU)... Well got to work everything was running great.. Left from work to get some food, got on it a little bit everything felt fine, i got up to the stop light and it started to die, ran like ****, rough idle. There is absolutely no smoke or anything comin out the back of the exhaust, im getting some new spark plugs to see if that is the problem. It almost feels like it is runnin on one rotor..
Old Jan 20, 2003 | 03:38 PM
paw140's Avatar
That doesn't sound too good. Check the MAP sensor hose before you do anything else.
I blew my motor Friday night. I floored it in 3rd gear about about 35 mph, and I lost power all of a sudden. I was able to tell immediately, though, b/c the car had just enough power to barely accelerate. But it ran really rough, and wouldn't idle.
Do you have a boost gauge? How is your vacuum?
Old Jan 20, 2003 | 04:02 PM
ejmack1's Avatar
Lawn Ornament
about 12 hg/mm or whatever its in...
Old Jan 20, 2003 | 04:17 PM
paw140's Avatar
I assume you mean 12 in of Hg. That's a little low, but is it lower than what you normally get? I was getting like 2 in Hg after my little stunt Friday night.
Old Jan 20, 2003 | 05:40 PM
ejmack1's Avatar
Lawn Ornament
i got aroun 16, iknow its low, but if its bllown shouldn't it be lower
Old Jan 20, 2003 | 06:12 PM
maxcooper's Avatar
WWFSMD
The vacuum gauge will often jump around at idle when the engine is blown, too. That can be more telling than the vacuum numbers.
-Max
Old Jan 20, 2003 | 06:31 PM
R Xplicit's Avatar
maxcooper is right. traditionally, the guage will be fluctuating when the motor has popped. definately do what paw140 said, and also check the throttle sensor connection. mine came loose once and it acted like a bad seal.....otherwise, do not drive it anymore, there can be debitremental damage done to the motor components and the turbos. i speak from experiecne.
paul, sorry to hear about your motor too. who are you looking to do the motor...or are you going to get a reman and just drop it in...or sell it?
louis
Old Jan 20, 2003 | 06:54 PM
ejmack1's Avatar
Lawn Ornament
well changed the spark plugs and its the same thing... im gettin scared now lol
Old Jan 20, 2003 | 07:34 PM
Joker's Avatar
another 13b rew bites the dust?
Old Jan 20, 2003 | 07:48 PM
CYM TKT's Avatar
hey, your car is on fire!
thats strange. when my motor blew I was pulling a constant 5 in vac. I checked the compression and it seems it was the front rotor that blew. I guess I killed more than 1 apex seal on it. mine went at 6500 in 4th. jsut all of a sudden boom.
Old Jan 20, 2003 | 08:04 PM
paw140's Avatar
Louis:
I'm in the process of pulling the motor... I'll probably end up getting a Mazda reman. I'm not really sure yet; I want to see the condition of the motor after I tear it down. I'm definitely not selling it, though.
Old Jan 20, 2003 | 09:55 PM
ejmack1's Avatar
Lawn Ornament
i guess ill do a compression test tomorrow im hoping it has to do with the spark though
Old Jan 20, 2003 | 10:07 PM
93BlackFD's Avatar
built my own engine
check the map sensor hose? on both ends?
reset the ECU?
Old Jan 20, 2003 | 11:08 PM
spoolin93r1's Avatar
mine was pullin between 10 and 12 in. of vacuum when i blew mine. i blew a seal on the rear rotor. sorry to hear about it man, just doesn't seem like a good time for rotaries right now!
Old Jan 20, 2003 | 11:33 PM
zooq's Avatar
mine also blew up this weekend. it still pulls 10 in and runs but the front rotor compression is 7.9 4.4 1.0
Old Jan 21, 2003 | 12:16 AM
ejmack1's Avatar
Lawn Ornament
Azevedo
26
Mar 1, 2019 09:19 PM
