What's up with the BAC!!!
Old Aug 13, 2001 | 02:03 AM
flak3r's Avatar
BAC removal
ive dont the throttel mod.. but was wondering if you could send more info on removing the BAC?? thanx
Old Aug 13, 2001 | 04:45 AM
Agent_D's Avatar
rawr
yea its perfectly fine to remove the BAC before the TB mod, i did it on the RX i wrecked in march, then i got the TB mod done later, just block off the hole where it was, run the coolant hose from the back of the water pump straight to the back of the engine and you are all set, no heating up the intake air more than it needs to be
Old Aug 13, 2001 | 04:52 AM
flak3r's Avatar
i see
so what happens with the plug that goes to the bac valve?? just leave that unplugged?? and plug up the hose that go to the IC as well?
Old Aug 13, 2001 | 07:13 PM
akageals's Avatar
If you have no A/C you can remove the valve although you won't be able to adjust idle except at the throttle stop. The BAC does not affect performance...i'd keep it but it's up to you of course.
Todd
PinkRacer
43
Oct 1, 2015 09:13 AM
Rotafuzz
Sep 30, 2015 09:55 AM
blackball7
Sep 20, 2015 08:33 PM
