my 88 T2 pass side pw window dosn't work.
Old Aug 12, 2001 | 06:48 PM
87jap951's Avatar
It had been working, but sometimes you needed to hit the switch maybe 2-3 times for it to work. Now nothing. Would the whole switch need replacing or maybe just a cleaning of the conections? I have had amny RX-7's with PW, but the first problem here.
Thanks much!
Old Aug 12, 2001 | 09:35 PM
Red2ndgen's Avatar
Do not buy a new switch. That is a waste of money. Neither of my windows worked when i got the car. All you have to do is pop out the switch with a screw driver, unplug it, and take it apart.(be careful as there a a few small peices that i almost lost in the door). Then clean the contacts with an eraser or fine grit sand paper. When you are done they should work like new .
Old Aug 12, 2001 | 09:54 PM
vaughnc's Avatar
knowledge junkie
We're assuming you don't have the safety rolldown switch enabled correct?
I almost thought I'd broken the window once because of that.
Old Aug 13, 2001 | 07:16 PM
akageals's Avatar
Yeah...what red2ndgen said! I'll add that the passenger window depends on the drives side switch to get it's power so i'd do the drivers side switch first and then see if the passenger side works...then clean the passenger side if needed.
Todd
Old Aug 13, 2001 | 08:42 PM
Cameljoe's Avatar
you didnt say which switch wasnt working. if both of them arent working then its the motor. If one works and the other doesnt. open the switch that isnt working and just clean the contacts.
Old Aug 15, 2001 | 10:14 PM
dcamcoTII's Avatar
Todd
Then if both of them aren't working couldnt it also just be the drivers side??
Old Aug 16, 2001 | 06:50 AM
turboedRX-7's Avatar
Thanks guys! It didn't need a motor, thats cool!
