3 Rotor NA what is its hps?
Old Jan 17, 2003 | 01:58 PM
Old Jan 17, 2003 | 02:21 PM
rxrotary2_7's Avatar
do a search. also... moving to 20B section.
Old Jan 18, 2003 | 12:55 AM
Evil Aviator's Avatar
Rotorhead
A "cheap" conversion from a 20B-REW would yield around 220-240bhp. Back in the day, Roger Mandeville was getting 450-475bhp on his IMSA GTO 3-rotor. I have heard rumors that some NA 20B's are getting up to 550bhp on SCCA GT1 cars, but I have not been able to verify this.
Old Jan 19, 2003 | 01:16 AM
Node's Avatar
This thread isn't even deservant of being in the 20b section. Someone please boot this garbage into the Lounge
Old Jan 19, 2003 | 03:59 AM
Bridgeported's Avatar
True, true, but since the 20B forum doesn't get much traffic as it is, I don't mind.
Lounge sucks.
Old Jan 19, 2003 | 04:17 AM
Node's Avatar
This thread sucks, don't make me bust out the this thread sucks picture!
Maybe if he would've said a little more, he wouldn't have been thought of as such a moron. Oh well, his fault.
Old Jan 19, 2003 | 10:13 PM
Rotorhead
Hey now, don't slam the nubie. I much prefer the more obtuse "what is the hp of engine X?" as opposed to annoying "I have A, B, C and D installed, so what is my hp?".
Old Jan 20, 2003 | 01:46 AM
Node's Avatar
Alright Evil. How much hp does a ported engine make
Old Jan 20, 2003 | 11:06 AM
j9fd3s's Avatar
Community Builder
213rwhp@9500rpms
mike
Old Jan 20, 2003 | 12:12 PM
Originally posted by j9fd3s
213rwhp@9500rpms
mike
That's more like a streetported 13B NA.
A bridgeported 13B NA will make anywhere from 200-270 rwhp.
NA 20B would probably be in the range of 200-400 rwhp depending on type of poritng (stock -> peripheral) and the state of tune.
Old Jan 20, 2003 | 03:44 PM
j9fd3s's Avatar
Community Builder
well knode didnt specify what kind motor did he?
mike
Old Jan 23, 2003 | 07:49 AM
adler's Avatar
Trying to get this thread back onto a technical track:
I presume you could just use the 2nd gen higher compression rotors and throw them into a 20B and run it NA.
Hitman in Auz has a 13b triple which I like the sound of. It has a custom centre plate to hold a stationary gear and as a result I guess it's slightly shorter which will be better for dropping it into a 3rd gen. It also has a custom eccentric shaft.
Anyone considered a 10a triple? Nice and small with a custome eccentric shaft.
Adler.
Old Jan 23, 2003 | 11:07 PM
Node's Avatar
wouldn't 10A parts be hard to get a hold of?!?!?
A 12A would be better I'd think.
Old Jan 24, 2003 | 04:19 AM
adler's Avatar
Er, good point. Loads of dead 1st gens kicking around.
Although a 10a triple would be nice and short and you might be able to get 250bhp from it if you tune it well. NA power to match the stock FD. Nice.
Adler.
Old Jan 31, 2003 | 04:20 PM
20B Junkie's Avatar
In one of the Hyper REV Rx-7 special mag with all the rx-7s and tuners. Theres is a article in japanese, i cant under stand it, but all i can understand on it is " 800HP! ", NA, not sure about ports, gas, etc.
Old Jan 31, 2003 | 06:18 PM
I can't see 800 hp out of an NA 3rotor.
The most I've ever seen on an NA 2rotor is about 360 rwhp.
I know of 4rotor engines (based on 13B parts) making around 850 rwhp NA.
(850 + 360) / 2 = 605 rwhp for a 20B
That's an EXTREMELY rough estimation, but it shouldn't be too far off the rear number for a peripheral ported 20B NA running higher compression rotors and tuned for lots of power instead of good powerband.
Just to show how it makes me doubt the 800 hp NA 20B. Then again... it was in japanese and it might have mentioned something else
Old Feb 4, 2003 | 05:04 PM
EScalade's Avatar
Variable Intake on the R26B and things like 3 plugs per rotor, dry sump etc give them higher output - around 750bhp.
20B PP 2 plugs oil pan and 55mm throttle bodies would make around 450-500bhp on a good day.
Old Feb 8, 2003 | 05:29 AM
1FooknTiteFD's Avatar
Ghost Ride the Whip
The RE Amemiya GT300 race car has a peripheral port 3 rotor NA that makes around 350 horsepower I believe..
Old Feb 8, 2003 | 03:30 PM
20B Junkie's Avatar
It makes 300, its in the GT300 class. But thats with restrictions too. Unless it makes more.....
I know the cars in the GT500 class keep HP under 500 which is max for that class, so im guessing its the same for the GT300.
Old Feb 9, 2003 | 06:26 AM
HyperRex's Avatar
I thought the 3 rotor engines in the racing cars were 13G engines, not 20B?
Old Feb 9, 2003 | 06:35 AM
Node's Avatar
the triple plugs were mainly for fuel economy and torque, but good **** none the less, variable intake was great. helped with power and torque.
i wonder what a r26b couldve made had it been tuned for max power. it was tuned for fuel economy and powerband.
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
jase03
26
Sep 29, 2015 10:36 AM
ZacMan
Sep 19, 2015 09:20 PM
