Changing Trans fluid - How to get off large square plugs
Old Jan 17, 2003 | 08:25 AM
misdbman's Avatar
Question Changing Trans fluid - How to get off large square plugs
How do you get off the small and large square plugs to drain/fill the fluid? I can get off the hex nut but you supposed to remove the small square plug also. An adjustable wrench with a hammer is not doing it. Also I cannot get the large square plug out to fill it. What tools are you guys using to remove these? Thanks
Old Jan 17, 2003 | 08:49 AM
misdbman's Avatar
Looks like a 12mm and a 14mm with a pipe on the end will work. The large nut is bigger than 22mm (my largest metric socket) so I used a 15/16" socket. Does anyone make a square socket to fit the plugs?
Old Jan 17, 2003 | 08:57 AM
rxrotary2_7's Avatar
did you change your name again? LOL!!
just use an open end wrench.
Old Jan 17, 2003 | 09:06 AM
SPOautos's Avatar
Hey, where did my $$$ go?
Yea, open ended wrench or a cresant wrench. I used teh cresant wrench
STEPHEN
Old Jan 17, 2003 | 09:39 AM
Scrub's Avatar
bow leggin'
you may need to attach an extra bar to the end so that you can get better leverage, thats what i had to do. that sucker was on there good.
Old Jan 17, 2003 | 09:43 AM
misdbman's Avatar
An open wrench did not work even with a hammer. But an open wrench with 2 ft of aluminum pipe flattened to fit over the open wrenches worked. I think the thread sealant was making it difficult.
I post with both names depending on which password I remember. Time to sync them both up
PS it is 2.6 quarts (2.5 L) to fill it. Used Mobil 1 75w-90 synthetic again (easy to get at PepBoys) but I think I'd like to try Redline MT-90, Royal Purple gear lub, or something similar next time...
Old Jan 17, 2003 | 09:45 AM
good!
Old Jan 17, 2003 | 10:02 AM
misdbman's Avatar
Looks like I will have to trek out in 1" of snow here since I am about 1/4 quart short. PepBoys is only about a mile away so I'm good. I seem to be having a shifting problem. It is Redline MT-90 or something else which everyone has been having luck getting 'scratchy' syncros to work again?
Just upgraded my home built AMD K6-350 to a Pentium 4 2ghz with 80gb drive . Reinstalled everything and of course the password cookies are not there. Also I'm current logged into work via cable internet and Terminal Services. My terminal server at work is not setup to save cookies. Just need to log out and get my email setup to send my password to me
Old Jan 17, 2003 | 01:23 PM
misdbman's Avatar
Here is a link to a comparison between Redline and Neo (go to the bottom of the page):
http://www.scuderiaciriani.com/rx7/oil.html
Now my problem is what NEO to get http://www.neosyntheticoil.com/gearoil.htm
There are (3) 75w-90 products. Which one to get?
Anyone ever compare Mobil1 gear fluid to Redline and to NEO?
What is the size of the large nut in mm? I think I will just buy the next couple of sized above 22mm next time I'm at Sears...
Old Jan 17, 2003 | 02:58 PM
FDjunkie's Avatar
I used NEO's 75w90 HD in both tranny and diff about 5K miles ago.
The1Sun
Mar 18, 2018 11:08 PM
alphawolff
Nov 17, 2015 05:57 PM
Akaviri
Sep 9, 2015 03:56 PM
Alexanderific
Aug 21, 2015 07:44 AM
highspeedrider
Aug 19, 2015 03:44 AM
