misFIRE..
Old Jan 17, 2003 | 12:08 AM
misFIRE..
my rx7's doing alot of misfire and i'm sure that my rx is getting enough fuel so i'm thinking there's something wrong w/ my spark plug or something! what r some good spark plugs to get? where can i get it and how many? thanks for your help thanks!
Old Jan 17, 2003 | 12:29 AM
DK's Avatar
DK
40k worth of fail
You're asking "how many" plugs you need? Yikes. You need 4. NGKs are just fine ... you can get them at most any parts store or from the dealer. Get two 7s (BUR7EQ ... or BUR7EQP for platinum), and two 9s (BUR9EQ ... or BUR9EQP) ... or just four 9s is fine, too. Make sure you put them in the correct hole ... they're marked on the plugs L & T as are the rotor housings.
Old Jan 17, 2003 | 10:11 AM
felix_is_alive's Avatar
while youre at it check youre wires ,there is also a ground for the little coil harness check if thats not also a possibillity
Old Jan 17, 2003 | 10:36 AM
Mahjik's Avatar
Mr. Links
What do you mean exactly by "misfire"?
Old Jan 18, 2003 | 03:34 PM
thanks DK i just ordered 4 9's
Old Jan 18, 2003 | 03:42 PM
FormerPorscheGuy's Avatar
Yes it is for sale.
I was wondering the same thing. Could you be mistaken in your diagnosis and be confusing "misfire" with back fire?
Reddraco
15
Jun 15, 2010 05:57 PM
bblee
West RX-7 Forum
20
Dec 15, 2009 12:45 PM
