Cooling System Mod
Old Jan 16, 2003 | 09:23 AM
MOSTIN's Avatar
Cooling System Mod
Does the engine runs cooler if you elimanate the AC heater core from the cooling system so the water can circulate alot quicker and provide better cooling?
Old Jan 16, 2003 | 03:43 PM
milkman2k52's Avatar
Why is this in the single turbo section?
Old Jan 16, 2003 | 10:41 PM
spoolin's Avatar
dude, is somebody tackling a washer machine in your avatar?
Old Jan 17, 2003 | 07:09 PM
MOSTIN's Avatar
I put in this section because when you go single turbo which means more power, your engine temp will rise from the normal operating temps, maybe not just cruising around (it should run cooler than normal with proper installation and tuning) but when it comes ready to race while turning up the boost or adding extra fuel your temps will surely sky rocket over normal temps. So I am trying every aspect of trying to keep my engine as cool as possible, even though I upgraded my rad and changing other cooling components.
My freind bypassed his core and he is trying to prove to everbody his car runs much cooler because of this mod
I am thinking, the more water you have the better it is for cooling, but is it becuase the water circulation is quicker or it reduces restriction?
Old Jan 18, 2003 | 09:54 AM
twokrx7's Avatar
Need more sleep
Bypassing the core made no diff in my car. If you have it plumbed, you can run the heater on high to combat those really high coolant temps. May get a bit hot in the driver's seat but it works.
Old Jan 18, 2003 | 05:19 PM
Actually its a trash can. It's a friend of mine that owns a 2g gst.
bryancmatthews
Power FC Forum
14
Oct 5, 2015 08:49 PM
dillrx7
Sep 7, 2015 09:38 AM
ray green
1st Gen General Discussion
Sep 2, 2015 06:35 AM
