newbie to rotarys
Old Jan 15, 2003 | 01:26 PM
13-bee's Avatar
newbie to rotarys
umm i am new to rotarys. i just want to know what kind of horse power i can get from a streetable n/a 2nd gen rx-7. and i was wondering what kind of 1/4 times i could achive with an n/a rx-7. i was told turbo is easier but i wanted to do something a little different. :0) thanks for your imput in the mean time....
Old Jan 15, 2003 | 01:51 PM
13-bee's Avatar
i know it sounds lame but i am just curious, i traded my geo metro for this car, so i thought what the heck might as well make it quick right??
Old Jan 15, 2003 | 03:32 PM
Bridgeported's Avatar
For how much power you can make will be determined by how much money you have to spend! (I know you can save money doing work yourself and buying used parts, but there is a point you have to pay to go fast)
Basically for a STREETABLE NA 13B, you are looking at a max of about 250 rwhp. This is acheiveable by bridgeporting the engine. If you aren't sure what that means, here is a decent page to read up on: http://www.rx7city.com/porting.htm
Your options for porting a streetable engine are streetport (mild or extended) and bridgeport (the limit for streetable). With the bridgeport your power should be between 225-250 rwhp depending on the size of port and quality of tuning.
If you arne't that familiar with rotaries (like know LOTS about them) then I highly recommend NOT to get a bridgeport. The engine requires specific work, and the maintenance is alot higher. All the tolerences on the engine are closer and more touchy so you have to know what you are doing to be able to have a successful bridgeported engine.
You probably would be best getting an extended streetport. You can get around 180-225 rwhp with it depending on the other mods and state of tune.
Hope this helps! Be sure to use the search function lots to research info, and we are here to answer more questions.
Old Jan 15, 2003 | 04:37 PM
Scalliwag's Avatar
WingmaN
Bridge is right. You need money and know-how to do this. One thing you need to consider; your car has what is called a 6-port. If you build a bridgeport or anything for that matter your have a lot of changes to be made.
Forget the ECU(computer), the fuel system and all. They would not be useable. Also you would need side housings from a turbo motor in order to do the port work.
To make more horsepower it will not come easy from where you are starting at.
As long as your motor ran good compression and seems strong, if it is your daily driver you should leave it alone.
You have a pretty big learning curve ahead and you need to get in a local RX-7 club and buddy up with some people who have cars you can see for yourself.
That will tell you how much they know and get any decisions ran across them before you ever jump into anything.
Old Jan 16, 2003 | 01:24 PM
13-bee's Avatar
cool thanks for the info. 225 horse power seems pretty good. right now i need to get a good running 13b so i can atleast drive it. ill look in the forum section for arizona people so i can start learning
Old Jan 16, 2003 | 02:50 PM
Head over to the Second Gen forum and read all the posts (or search) there. There is a lot of info there which can probably help you make your deceisions easier.
datfast1
Old School and Other Rotary
18
Jun 20, 2019 10:53 PM
Under PSI
19
Sep 23, 2015 11:47 PM
datfast1
West RX-7 Forum
Sep 14, 2015 06:58 PM
andyvideopro
SE RX-7 Forum
Sep 5, 2015 06:56 PM
Murilli
Midwest RX-7 Forum
Sep 3, 2015 09:10 AM
